How Super-Symmetric can SuSy be? - Page 2 - diyAudio
Old 9th December 2003, 03:20 AM   #11
Account Disabled
I think that the X-feedback cancells the signal distortion so much as controlled. And, the asymmetric cancellation of common mode signal is added to the total offset output voltage. I try to solve my problem from this point. Probably, I'm very wrong.
Old 9th December 2003, 11:03 AM   #12
grataku is offline grataku  United States
SuSy is just a buzzword
Common mode cancellation comes from the fact that the amp is differential, and has nothing to do with Susy.
You can either stop there and have nested differentials (BLS+ SOZ) or add feedback to connect the two stages. There are not many ways to achieve negative feedback with nested differentials.
When applicable, the idea is clever and it can be argued that the whole is more than the sum of the parts.
Without pulling Nelson's papers out, I don't recall seeing improved measurements for the SySy circuit. I can remember a lot of peanuts and chocolate that usually irritate my intestine.
Old 11th December 2003, 07:08 PM   #13
Bernhard's Avatar
Hi Hugo,
I got it
Picture shows a 10kHz sine from a not so good Siemens function generator.
Marker is on 10kHz and cursor on 20kHz. 2nd harmonic is -55,7dB, there is a lot of other dirt like strong third harmonic and very strong 7th harmonic and even disharmonic crap.
Another better sine generator shows only 2nd and very little higher harmonics.
I can see down to -75dB very clear frozen curves without noisfloor by averaging up to 500 or more measurements and storing them.
Averaged & stored curves may be subracted from or added to each other
That means I can test all my madness circuits and see what's up
Greetings, Bernhard
Old 11th December 2003, 07:18 PM   #14
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
This must be a picture from the harmonics of a Madness circuit taken with your new toy.
Please elaborate a bit. How did you measure what?
/Hugo
Old 11th December 2003, 07:22 PM   #15
richwalters's Avatar
Weak signal from Explorer.....somewhere beyond solar system...
elaborate. SVP
rich
Old 11th December 2003, 07:26 PM   #16
Bernhard's Avatar
Talking I'm in love with a machine
see edited post
Old 11th December 2003, 07:28 PM   #17
It's more like: "I got a big spectrum analyzer but I don't know how to use it"...
Old 11th December 2003, 07:34 PM   #18
Bernhard's Avatar
I'm sure your's is bigger than mine
Don't worry...
Also the sine generator curve can be subtracted from the amp (+generator) curve, so the pure amp distortion is left.
Before doing serious things I have to play a little.
Old 11th December 2003, 07:39 PM   #19
Netlist's Avatar
I also want a toy like that....
/Hugo
Old 11th December 2003, 07:48 PM   #20
eLarson is online now eLarson  United States
eLarson's Avatar
Default Super Symmetry as I understand it
The thing about SuperSymmetry is that it uses feedback around each half to make each half look more alike.
As far as I can see, it really works the same way as a regular differential circuit... it's just that we now have two halves matched better than normal, thanks to the feedback applied to each side.
edit: I believe it is supposed to 10x better than just regular differential. (factor of 100 cancellation vs. factor of 10.) I, too, am going by memory... ('watakashi-no kyoku-ga tashika naraba...')
eL
Would a woodchuck bother to chuck MDF?
need help for bridge or symmetric amp hobby1 Chip Amps 13 5th October 2008 07:43 AM
Discrete Super Symmetric(I think) Opamp for I/V Etc... Russ White Pass Labs 37 24th June 2008 12:16 AM
symmetric amplifier Rambi Solid State 35 21st December 2002 09:48 AM
Audio Crafters Guild "Super Symmetric Power Supply" raincheck Digital Source 16 22nd April 2002 08:06 AM
Copyright 1999-2017 diyAudio
