F5 Front end JFETs substitute - diyAudio
Old 10th June 2013, 11:06 AM   #1
Default F5 Front end JFETs substitute
Hi All,
I remember seeing a post by Mr. Pass that the front end JFETs can be replaced by Fairchild J174, J175, P1086 for P channel and Fairchild J111 for N channel. Has anyone tried any of the combinations above, and how's the result?
And if I were to have a go at it (coz I ordered a set of K170 and J74 from china, in case those turned out to be fakes I would have to consider replacements) would I need to make any changes to the circuit to accommodate J174 and J111?
Best regards
Liu
Old 10th June 2013, 11:43 AM   #2
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
see this : F5 amp transistor kit
however , regarding your question , look for posts made by jackinnj
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th June 2013, 12:58 PM   #3
Thanks Zen Mod. I read through the many posts that a search yielded, and I still havent found the solution I was looking for, mainly because the board that I have now only has space to accommodate 1 device instead of a few paralleled ones (maybe I am not looking at the right posts?). Is there any 1 to 1 substitute that might work? I think I can accept it if the noise performance is not as good as the original part.
BR
Liu
Old 10th June 2013, 01:34 PM   #4
Zen Mod's Avatar
you can always put 2 parts in space for one , by piggyback approach - one part top of pcb , other at bottom
Idss is what you need to take care of ; say that you need 6-9mA ,while difference in xconductance is what you will have as unavoidable
anyway , in your boots , I would buy originals from h_a or Spencer
Old 10th June 2013, 03:12 PM   #5
ah.....never thought of that.....
Well, since this is my experimental build, I might just go ahead and put in the set from china. Hopefully I would be able to bias up the amp and hear some music out of it and not blow anything up. Buying originals from one of the 2 gentlemen would probably be the best option when I finished the practice and feel confident enough to start the actual build with diyaudio F5T beta boards which I already have lying there waiting....
Old 10th June 2013, 05:10 PM   #6
Zen Mod's Avatar
test Jfets prior to puttin' them in pcb
Old 11th June 2013, 03:48 AM   #7
Yup. I will do that....I assume the method that was discussed in post #11250 of the F5 thread would suffice?
Old 11th June 2013, 05:43 AM   #8
expert in tautology
bear's Avatar
that will give you Idss.
The bogus jfets test fine for Idss, however the curves do not match between the Pch and Nch devices. This means that the amplifier will run fine, but there will be a difference in distortion between an amp with genuine parts (well matched) and counterfeit parts.
Now, this may not sound all bad. There is a difference between amps built with the Fairchild devices (not exact compliments) and the Toshiba (very close, almost exact compliments). So, I might suggest that there are 4 basic flavors:
- complimentary input + complimentary output
- complimentary input + asymmetrical output
- asymmetrical input + complimentary output
- asymmetrical input + asymmetrical output
Generalizing...
_-_-
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 11th June 2013, 09:52 AM   #9
Err....this is a bit too deep for me....assuming that the parts that I get are indeed bogus, that would mean that I will have the 3rd flavor, i.e. asymmetrical input + complimentary output (I got the output IRFP240+IRFP9240 from Element14 so I assume that they should be real)? And how bad can the distortion be?
Old 11th June 2013, 01:32 PM   #10
expert in tautology
bear's Avatar
Only the Toshiba output devices show essentially identical transfer curves between N and Pch.
Don't panic.
The distortion will likely be mostly 2nd and 4th harmonic, which sounds good.
I'm not sure if anyone, NP included, has put up distortion spectrum and distortion vs. power for these variations or not. So, I can't give you any figures. But it is clear that the asymmetrical combination in the output stage yields more (mostly even order) distortion. Many people reported preferring the "sound" of the Fairchilds over the Toshiba.
Worst case build with what you have, and change the input devices later. Perhaps consider some high quality sockets for the jfets?? (or some pins in the holes and solder the jfets on top of the board... etc.)
_-_-bear
Can anyone recommend a complimentary pair of SMT jfets for F5 JZatopa Parts 4 9th October 2015 06:39 PM
Potential mathed JFETs for Balanced F5 build NYCOne Swap Meet 3 22nd May 2011 07:11 PM
WTB matched jfets for F5 ! komigenie Swap Meet 4 16th March 2011 01:54 AM
WTB: 2SJ108 and 2SK370 JFETs for F5 nl Swap Meet 1 24th September 2009 01:31 PM
WTB: 2SJ108 and 2SK370 JFETs for F5 nl Group Buys 0 22nd September 2009 09:06 PM
Copyright 1999-2017 diyAudio
