Starting to build my first F5 Turbo V3 - Page 9 - diyAudio
Old 8th July 2013, 05:56 PM   #81
WalterW is offline WalterW  Netherlands
Originally Posted by 2bz View Post
Here are the results that I came up with for each of these particular vias:
Nice website...so around 6 ampere, that's more than I expected...
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6
Old 8th July 2013, 07:02 PM   #82
2bz is offline 2bz  United States
Yeah, but 30C/watt of thermal resistance is also concerning! If I am running 12W per Mosfet, does that mean these little vias run at 380C, assuming a 20C ambient temperature?
Old 8th July 2013, 08:11 PM   #83
No, through the vias goes the current when the diode is conducting, that's when there is more then approx. 0.4 volt over your source resistors. That will be only when playing loud or heavy bass peaks...
Normally they are not conducting.
Old 9th July 2013, 12:32 PM   #84
So....To drill (more/larger vias) or not to drill, that is the question.
Old 9th July 2013, 12:55 PM   #85
It's a double sided board.
What traces are on the other side of those diode leads?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th July 2013, 05:53 PM   #86
On closer inspection, space is quite a bit more limited than I originally suspected. I can drill out the current via and solder a 1.5 MM copper wire in place or leave it as it is. Thoughts on either option?
Old 7th September 2013, 09:16 PM   #87
I have been away from this project for a while but now I have all the components and have started putting together the frame/cooling loop. Thanks for everyone's help, to date. More to follow.
Old 7th September 2013, 09:56 PM   #88
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
See attached picture.
I don't know how much ampere can get through such a small hole. Maybe someone here knows?
looks like the hole has area/surface equal to the copper line
if anything only the edges might cause problems
sometimes we know very little, and sometimes we know too much
Old 8th September 2013, 06:06 AM   #89
nashbap is offline nashbap  United States
Good to see you back 2bz. What PSU board are you using?
Nash
Old 10th September 2013, 12:22 PM   #90
Nash
Super Heavy Duty Powr Supply Board CRC for Pass or Class A Dual Mono PCB | eBay
Operating Vgs and Yfs matched 2SK1530/2SJ201 for the F5, F5 Turbo and F5X NicMac Swap Meet 24 15th November 2016 06:20 PM
New Build Recommendation: F5 v3 or Aleph X chuckd Pass Labs 29 4th March 2013 08:48 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
Is it wrong in F5 TURBO V3? lilinyi Pass Labs 12 23rd November 2012 07:28 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
Copyright ©1999-2017 diyAudio
