Starting to build my first F5 Turbo V3 - Page 2 - diyAudio
Old 28th May 2013, 03:36 PM   #11
Marra is offline Marra  United Kingdom
Check with Buzzforb he was selling matched sets of other FQA's.
Old 28th May 2013, 07:14 PM   #12
6L6 is offline 6L6  United States
6L6's Avatar
IRFP240 / IRFP9240 Would work in the circuit. Buy a tube or two of each, make a simple match rig, you will probably get enough good matches for a few amps, use one set, you can sell off the rest for what you paid for the lot.
Old 28th May 2013, 08:04 PM   #13
2bz is offline 2bz  United States
Thanks for the tip. BTW, is a FQP12P20 the same as a FQA12P20 except for the packaging? The spec sheets look similar but not exact.
Old 28th May 2013, 08:19 PM   #14
6L6's Avatar
Do you mean Buzz's Fets? Yes, that's my understanding. He verified with Fairchild that his are all genuine -- I have used plenty of his Fets and am very, very happy with them.
Old 28th May 2013, 08:30 PM   #15
No, I meant in general. If I buy a Farichild FQP12P20 from Arrow or Digikey, do I essentially get a FQA12P20 in a TO-220 package?
Old 28th May 2013, 08:36 PM   #16
6L6's Avatar
You don't want TO-220, rather TO-3P or TO-247. A TO-220 device will have a much smaller dissipation rating.
Old 28th May 2013, 08:44 PM   #17
I see. Thank you.
Old 30th May 2013, 07:43 PM   #18
This amp has 16 MOSFETS: 2 channels, w/ 4 pos/neg pairs each. If I want to match the Vgs to <100 mV, does that mean: (A) All 16 must fall within 100 mV, (B) All of the positives must fall within 100 mV and all the negatives must fall within 100 mV, (C) Each pos/neg pair must fall within 100 mV, (D) other?
Thanks.
Old 30th May 2013, 07:46 PM   #19
B. all positive for one ch. and all negativ for 1 ch.
Old 30th May 2013, 10:26 PM   #20
6L6's Avatar
B) Match the N-channel to the N-channel and the P-channel to the P-channel. The bias pots will make up for the N's and P's not matching.
Operating Vgs and Yfs matched 2SK1530/2SJ201 for the F5, F5 Turbo and F5X NicMac Swap Meet 24 15th November 2016 06:20 PM
New Build Recommendation: F5 v3 or Aleph X chuckd Pass Labs 29 4th March 2013 08:48 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
Is it wrong in F5 TURBO V3? lilinyi Pass Labs 12 23rd November 2012 07:28 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
Copyright ©1999-2017 diyAudio
