out board power supply connection
Old 16th May 2013, 08:52 AM   #1
slr 5000 is offline slr 5000  Australia
Default out board power supply connection
g,day all
Just about to build an outboard power supply so i can easily switch between my different fw clones with a simple plug in/out
I have a few questions regarding the best lead to use to connect the power supply case to the amplifier case/s
i,m thinking a 3 or 5 din plug with standard 3 core mains wire
any suggestions/advice would be much appreciated
rgds Sheafer
Old 16th May 2013, 09:28 AM   #2
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
I would use a plug with meatier pins than a standard DIN plug.
Old 16th May 2013, 09:39 AM   #3
Any suggestions?
i was thinking normal ac plugs but they only come on 3 pin and i need 5 pin
Sheafer
Old 16th May 2013, 09:41 AM   #4
something like this
5 Pin NYS322AG Rean Gold Plated Midi DIN Data Connector on eBay!
Old 16th May 2013, 10:16 AM   #5
flatheadmurre is offline flatheadmurre  Sweden
Check fo russian Cannon plugs from military surplus.
I use them and when the surplus runs out the originals still around for ridiculous money....
Old 16th May 2013, 10:18 AM   #6
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Speakon or Powercon
there is variety of types ; choose on
they're good enough for XS-es
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th May 2013, 10:45 AM   #7
Thanks guys
are these the ones Pack of 4 8 pole Speakon connector with a metal latch lock for speaker cables. Can handle 8-16 mm cables.
i presume 8 pole means provision for 8 different wires/connections
cheers Sheafer
Old 16th May 2013, 10:48 AM   #8
Speakon and XLR both make good high current multi-pole connections.
But, the problem is that these are normally used for other duties.
How would you ensure they are never connected to the wrong socket?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 16th May 2013, 10:57 AM   #9
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
power amp and extern supply ?
Originally Posted by Redshift187 View Post
No. Use something that is different than what your mains power is. It's the only safe solution.
IEC comes in a big variety, you don't need to use the same ones as your mains. I didn't.
My mains on the left. My DC cable on the right:
Old 16th May 2013, 11:05 AM   #10
hi all
i would use the standard iec recepticle/power cord for power in to the power supply case and the speakon connectors for power out to the amp case
it would therefor be impossible to mix up the connections
Sheafer
out board power supply connectionHide this!Advertise here!
Please help me mend this power supply board. dublin78 Power Supplies 7 29th May 2012 04:48 AM
Power Supply PCB board juliovideo Power Supplies 5 29th November 2011 06:42 PM
Switching Power Supply Board Perry Babin Car Audio 0 14th September 2011 03:11 AM
How to do the best of connection in multi-CAP power supply ckwong99 Solid State 22 30th July 2009 11:50 AM
power supply choke with a connection for AC ground? jarthel Tubes / Valves 4 16th March 2007 10:10 PM
Copyright ©1999-2017 diyAudio
