The Beast with a Dozen Jfets
Old 15th May 2013, 01:23 AM   #21
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Originally Posted by wrenchone View Post
Can you get what?
Oh, sorry. Just a pc board if you'll be making them available.
It looks like a great project.
Old 15th May 2013, 06:01 AM   #22
wrenchone is offline wrenchone  United States
wrenchone's Avatar
Neither of us will know that until I get the project finished (or at least breadboarded) and actually listen to it.
At any rate, I don't offer boards or kits for anything that I show here at DIYA, as I barely have enough time to realize the ideas in question. I then move on to the next one. There's a pile of projects in the basement (lots of them vacuum state) begging to be finished. If you are interested enough, a lot of the things I present can be readily thrown together on Vector/Vero/perf board. It may not be as pretty, but it works just as well.
Old 20th May 2013, 02:02 AM   #23
wrenchone's Avatar
I'm going to dump this project on a relatively small heat sink and use an auxiliary fan for cooling. I picked up some 12V fans from Electronic Goldmine that draw less than 100ma full tilt, and are dead quiet. Just a whisper of air is enough to get things done if the heat sink isn't too small. Next I have to find the Transcendar 3k output transformers I had in mind for this project.
Old 1st June 2013, 10:57 AM   #24
wrenchone's Avatar
Found both 3k transformers - this project may get done sooner or later.
Old 11th June 2013, 01:43 AM   #25
wrenchone's Avatar
The project is marching along - the boards are mounted to heat sinks with all I/O and power leads/jacks installed. Output transformers will be spliced in using wire nuts so that I can yank them out if the sound displeases me. Final feature will be a shroud around the heat sink to allow cooling via a teensy 48V DC fan powered from the 30V supply. I may give in to expediency and rig something out of cardboard rather than bending up sheet metal.
Old 11th June 2013, 08:49 AM   #26
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
lurking .......
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th June 2013, 01:36 PM   #27
6L6 is offline 6L6  United States
6L6's Avatar
You are not the only one...
Old 12th June 2013, 04:10 AM   #28
wrenchone's Avatar
Here's something to think about it in the mean time. I'm doing the HV/transformer coupled routine to get the best bang out of a limited number of jfets and a relatively low total bias current (100ma). I pooh-poohed doing a lower voltage version due to the huge number of jfets involved. However, I do have some J107s that are lounging around looking for gainful employment. The have a minimum 100mA IDSS, so one jfet could easily support 30ma bias current if you clamped the VDS to 4V with a cascode. So, instead of 100 fets, you would only need 33 for a reasonable bias current target of 1A. The fets also have a hefty gate capacitance of ~140-150 pF apiece, so the assemblage would really need a follower for drive. I don't know if this approach would be good or "SLS". I'm not even thinking of doing something like this until I get a bunch of other stuff off my plate - maybe not even then. However, the more ambitious among you might want to give it a try.
Old 13th June 2013, 12:17 AM   #29
wrenchone's Avatar
Note -the other reason I mentioed the J107 in my previous post is that that are still around cheaply as NOS with a little searching. There are other chopper/switch fets with similar ratings.
Old 17th June 2013, 05:11 AM   #30
wrenchone's Avatar
Tonight I took the hot-doggers approach, carting the amp down to the basement and powering it up a side at a time, using an electrophoresis supply for the HV and a Topward bench supply for the LV and a small DC fan. I used a Discman for a signal source.
No smoke was emitted, bias was stable (~100ma/side), and sounds were made. Next up is carting the mess in to work for characterization and engaging the global feedback. Right now, the gain with just the partial feedback is pretty high, so that adjusting the volume is touchy. I'll probably need to adjust the ratio between partial and global feedback.
The Beast with a Dozen JfetsHide this!Advertise here!
Beast with a Thousand JFETs Nelson Pass Pass Labs 297 18th May 2013 12:38 PM
Article: Beast With a Thousand Jfets Nelson Pass Pass Labs 95 28th February 2013 06:28 PM
FS: Dozen 71A and dozen VT-67 DHTs andyjevans Swap Meet 0 24th August 2011 07:49 PM
One Dozen Wima MKP4 10uF 250V caps stellavox Swap Meet 0 21st May 2010 12:41 PM
1/2 of Mark's Baker's Dozen hooha Subwoofers 8 27th October 2006 07:44 PM
