Hi All
I am soon to commence (i hope)my Aleph 5's but am unsure as to which way to go with power supply. i have the following bits 4 off 80000uF caps + 2 chokes 2 off Tranformers each 25-0-25 @ 50A The dilemna, do I go single supply with total 160000uF per rail (320000Uf total) with either 1 transformer or 2 in parallel? This would also involve use of chokes between caps( for a pi? filter??). or dual mon supply with i transformer per channel and 80000uF caps per rail for a total of 160000uf per amp. - no chokes though Any comments welcome.. Thanks in advance
george a |
#2 |
Or I could do this to power subs as well (plus P1.7 Preamp)....
george a |
#3 |
actually -correct wiring of the diodes and caps would work ebven betterer! ....doh!
I'm sure you all get the idea..
george a |
#4 |
The production Aleph's don't use a coil in the powersupply. So I would suggest to use 1 trafo+ 160.000 uF a channel. I would not recommend to power also your preamp from the same supply, The P1.7 needs a 60 Volts (dual 30V secundair for your trannies) I don't see how you want to get this wiht transformers with 25V secundair voltage.
#5 |
Taco
thanks for reply if you at posted schematic you will see wher i'll get higher voltage from, which can then be regulated for the P1.7.
george a |
#6 |
Now I see what you'r doing :P, this only works with 1 common supply but don't you get an uneven load on those trannies. Don't know of this matters.
#7 |
It depends on how you are going to cool them. If they are built in as stereo you will not be able to lift them unless there are fans. The stereo A-30 that I built with the R-theta heatsinks is 72 pounds. It has a 20 degrees rise. The mono blocks will be more work but easier to move.
MikeW |
#8 |
Taco
Transformers each rated at 2.5kva , preamp load probably. not an issue I beleive alpeh 5 draw constant current and hopeffuly wont react with supply to preamp. Subs supply (feeding Hafler dh200 clone) may be a different story though. if this proves a problem then i have a spare Hafler to use as a stand alone bass amp. Am just trying to get the poewr for the preamp from somewhere without having to by another transformer. Also trying to keep things a bit more compact
george a |
#9 |
MikeW
I am thinking of fan cooling + 2 boxes - one for Power supply and one for power amp. Will probably still weigh in at about 70 pounds anyway.... Transformers currently power hafler clone and I can carry it short distances only. I will probably also need some hefty cables for linking the 2 boxes- may put half of caps in amp box...(160000uF)
george a |
#10 | |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| Dead Adcom GFA-565 Monobloc | mjraudio | Solid State | 213 | 7th November 2011 10:37 AM |
| My new monobloc layout for Mauro Penasa's MyRef Rev. C | Russ White | Chip Amps | 32 | 22nd December 2010 03:55 PM |
| "Mr. ED" Non-Inverting monobloc chip amp group buy. | Russ White | Group Buys | 25 | 1st May 2010 08:14 PM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.10058 seconds (78.02% PHP - 21.98% MySQL) with 11 queries |
