HI,
Unfortunately my 4000 amp is 100% dead ,so I have to recicle cabinet and PSU. I have +/- 75 volt B+ ()MONO). I like the Series, so I have asked in france ( see treshold lovers website) to a lab that restore Threshold amps, but they have responded that the amp is not compatible with more modern type.!! ![]() ![]() ![]() So I ask if some kind good guy here, can make physycally two plates of alluminim of 6 mm thick ( to screwing to my heatskins that are 340 per 145 mm) with attached the entires channel of SOMETHING good ( if threshold or Pass better of course because I am alovers of the brand of mister Pass) of about 200 watt / 8 ohms. My power transformer is 1000 VA ,SQUARED - not toroidal - and the capacitors are 4 Cornell Dubiler 15000 microfarad /80 volt still working! ![]() I hope To have some good news from someone here... ![]() Obviouslly I0' ll pay money bank or paypall the value of the work plus materials. P.S. I love AB class with little % of clas A operation because thae amp is only for bass zone ( 20 - 350 Hz) and I would save heat. ![]() Thanks for reading! Cheers Paolo Pontello - Phaseless High end Speakers |
#2 | |
More info, please? |
#3 |
Yes, you are right.
I have two heatsinks 340x345mm with a lot of holes, so I have to attach over it a plate of 6mm of alluminium, where to fix the new plastic transistors and all the components & circuits, PSU excluded. I think it's possible, because 99% of amplifiers class AB works with a dual B+ of, in my case, 75 + or - Volts. So I don't see any difficults. In facts, I have asked to AussieAmplifiers and they have suggested me their modules NX300 that it's beautiful modern amp but I'am nostalgic and would like to put a Threshold amp in a Threshold cabinet! ![]() Thanks for reading. |
#4 |
The one and only
You can still get TO-3's through distribution. Digikey and Mouser have parts
like STMicro BUX48, BUX 98 and 2ST2121 in stock. Also, when you say 100% dead, what do you mean. Have you tested the devices?
#5 |
Dear Mr. Pass,
I have taken my 4000 in laboratory, and they have said that all transistors (power and signal) are destroyed. ![]() In addition, they can't guarantee a repair, even at about 600 Euro cost. At this point, my interest is in more musical and modern, IMHO, S350 or S450. Do you think it's possible? Do you know some kind guy, maybe in Europe, that can do the work? Thank you very much! |
#6 |
pictures can't do any harm
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#7 |
Pictures please. To loose all the transistors and not have a lot of magic smoke let out and a blown transformer is very unique .
#8 |
Hi all!
I can send the pictures, but I don't understand the reason. I have specified as the technician of the lab that repair amps have said that all 24 power transistors for channell are dead. And also all the signal transistors. From the photo nothing useful can be seen - the transistors appears normal. There's no sign of fire, or melted components, etc. Thanks for reading. |
#9 |
The one and only
You said they said "all transistors (power and signal) are destroyed".
I doubt that this statement is true. Now it is possible that all power devices are destroyed, but I have never seen such a case. I have met technicians who would say such a thing without doing the amount of work necessary to confirm that. Since you would have to take every transistor out anyway, I suggest you do so carefully and test each one.
#10 |
last time when Witch Hunters were cohorting my little place , I was forced to hide my crystal ball
later , when they ( WH) goes away , I spotted that price for hiding my crystal ball in hurry was scratches all around unfortunately - masters these days aren't so good in crystal polishing , as they are good in simple swapping of LCDs , so my (crystal) ball is waiting for some ole master , to make it useful , again that's the reason why I need pictures to see posted - here - my remote device for remote observing of ooked remote devices is ooked
| ma audio hk-4000 ,no sound to subs ?MA AUDIO HK-4000,NO OUTPUT TO SUBS | WRENCH030380 | Class D | 2 | 7th March 2011 11:38 PM |
| Threshold 4000 | R-K Rønningstad | Pass Labs | 10 | 28th August 2009 04:27 AM |
| WOZ: Wife Of Zen concept (Courtesy to NP) | Wavebourn | Pass Labs | 10 | 17th April 2009 05:27 PM |
| Threshold 4000 & Receiver attached to same speakers | hrad | Pass Labs | 2 | 6th June 2005 06:33 AM |
| Threshold 4000 "polarity" | inertial | Pass Labs | 2 | 11th March 2005 11:10 AM |
