Troubleshooting F5 - Dennon AVR 4603 hookup
Old 4th May 2013, 11:12 PM   #21
toxic ingestion is offline toxic ingestion  United States
More experiments and data collection today, and problem solved.
First, we used the scope to monitor output on the HDMI cable out of the television while the TV was on standby and could not detect any signals.
We then hooked the HDMI cable back up to the unplugged (no power) Dennon receiver and monitored signal from the preamp outputs on the back and could detect no signal.
Then we opened the F5 and monitored from the RCA jacks taking input from the Dennon Receiver. With the following conditions:
1. TV on standby
2. HDMI connected between the TV and the Dennon receiver
3. Preamp output of the Dennon receiver to the F5
4. BUT, with NO POWER to the F5
and we could detect no signal on input to the F5.
As soon as we powered up the F5, we could detect swings between about +2.5VDC and -2.5VDC on the input to the F5. These swings began at about 1 Hz and then gradually increased in frequency.
F5 was powered down and we set up to monitor output from the F5 across 10 ohm power resistors (in place of speakers) on channel two of the scope. Under the same conditions, we saw the identical pattern, except the swings on output from the F5 were from +6VDC and -6VDC (F5 has 24VDC rails unloaded and biased to 1.3 amps). I posted a video of this on YouTube and the following link:
Troublehooting F5 - Dennon receiver - Pioneer HDTV hookup: F5 input and output on scope - YouTube
We connected ground wires from the case of the Dennon receiver and the F5 Ė no effect.
We confirmed that the same phenomena was seen with the F5 turbo amplifier, except that voltage swings on output where higher (rails 30 VDC under load).
So, we then changed out the HDMI cable and the problem disappeared. Everything is working fine with the new HDMI cable.
Perhaps someone will be able to explain exactly what was happening, but I certainly canít. It certainly appears that because of a bad HDMI cable, a parasitic oscillation was set up within the F5 that began quite slow (about 1Hz), and that the signal that set this off was injected into the F5 by the TV through the unpowered Dennon receiver. Fortunately, all problems disappeared with the new cable. Maybe this post will be of assistance to someone 8 years from now with a similar problem.
Thanks for all the suggestions.
Troubleshooting F5 - Dennon AVR 4603 hookupHide this!Advertise here!
Operating Vgs and Yfs matched 2SK1530/2SJ201 for the F5, F5 Turbo and F5X NicMac Swap Meet 24 15th November 2016 05:20 PM
My Dead Arcam 200 AVR project/helpHi all 0/ Basically I have an old Arcam 200 AVR tha Fivetide Solid State 4 5th July 2011 07:18 PM
Rockford Fosgate Platinum 2000 Car CD Player Dennon DZ1 tenderland Swap Meet 0 27th November 2009 09:35 PM
Dennon POA-6600A Yvesm Solid State 5 15th January 2008 05:17 PM
Dennon 2910 - not reading discs MurrayP Digital Source 6 15th October 2006 12:57 AM
