Aleph 5 DIY- with Dolphin sounds...Help please - Page 5 - diyAudio
Old 13th June 2013, 01:20 PM   #41
Mooly's Avatar
Sounds like you are anticipating problems...
Lets hope you crack it with this rebuild.
Old 13th June 2013, 01:43 PM   #42
update
it wasn't the daughter board......progress!
george a
Old 13th June 2013, 09:19 PM   #43
teeker is offline teeker  United States
this might have been covered, but make sure there are no burrs around the mounting hole of the mosfet in question and the surface is smooth. burr will or could punch throught the insulator and short the drain to the heatsink.
Old 14th June 2013, 05:38 AM   #44
thanks teeker
i will check
good call!
george a
Old 23rd June 2013, 03:38 PM   #45
Hi All
Back again
after various pressures and priorities I found myself doing a complete (newish) build as I had a couple of spare A5 pcbs floating around....
It worked first time with all voltages ok...so that is very reassuring and pleasing .
So the A5 is installed back in the system and singing as sweetly as ever.
though not very hot as its fan cooled with large heatsinks (only abt 15deC rise over ambient..)
I really don't know what the problem was but interestingly a few odd parts appear to have fried themselves without me noticing - particularly the Source (1 ohm ) resistors.....
Anyway - I now have a few mosfets to check for damage (some shorted and some reading a very low Vgs..)
I still don't know what the problem was - and will as time allows do a rebuild on my 2 spare pcb's with the intention of placing them in my triamp system to cover 80hz-650hz, the repaired Aleph is covering from 650hz up...
One issue that has arisen is that when I fired up the amp I connected a "sacrificial" speaker just in case something was untoward- no probs except for buzz which is not really noticable on the main speaker (ribbon).
Now that I have an oscilloscope i had a look at the output with inputs shorted and noticed an odd looking waveform. ($40 for a 2nd hand CRO- money well spent!)
The strange waveform was also present on the power supply + & - with no load attached (no amplifier load as it a 2 box unit and I disconnected the power feed to the pcbs')
It could be some dodgy caps (4 x80kuF) or the diode bridges (2 squre box style wired in paralle.
I'll post an image of the waveform to see if anybody cleverer than I knows what it means ..
Most importantly - a big thanks to all have helped in getting the amp working again.
Your guidance , suggestions and observations are all very much appreciated.
I hope i can return the favor to the forum every now and then.
cheers from down under
george a
Old 23rd June 2013, 04:17 PM   #46
Mooly's Avatar
Thanks for the update George. Pleased to hear you have a working Aleph once again.
Yep, you can post the 'scope waveform and we'll hazard a guess
Old 24th June 2013, 11:40 AM   #47
well here tis
photo of scope view- as best as i can do
frequency of pulse i think equates to 100hz with abt 0.03v peak to peak voltage. (yes i calibrated the scope)
this is taken at the terminal of one of the power supply caps with no load on the power supply other than some bleeder resistors- abt 160ohms.
amp is totally disconnected.
power supply consists of:
a) 1 trafo - supposedly 50v ct with 50A secondary
b) 2 diode bridge blocks in parallel
c) 4 of 80kuF caps (total for + &-ve)
d) 160ohm bleeders per rail.
e) 1 small cap across one of the diode bridges
when i connect the amp i can hear a bit of a buzz through a highish efficieny speaker, but is pretty inaudible with the ribbons the amp usually drives.
amp is connected to the ribbon via a matching transformer.
Is the waveform telling us anything?
thanks in advance
george a
Old 24th June 2013, 11:56 AM   #48
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
160R bleeders are loading it too much
say that 1K is mucho better
besides that , everything seems normal
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th June 2013, 12:06 PM   #49
Thanks Zen mod
I'll change over the little bleeders and report back
many thanks.
BTW the amp sounds wonderful- my kids use it a lot - they don't know just how good they've got it...thanks again papa
george a
Old 24th June 2013, 12:11 PM   #50
Mooly's Avatar
Sawtooth ripple like is what you would expect to see. That all looks perfectly normal.
If you can hear this ripple (and it will be far higher than 0.03 v pk/pk with the amp drawing current) then the two main possibilities are a less than perfect wiring scheme whereby some of that voltage is developed across and conductor and finds its way into the amp, and/or the ripple rejection of the amp itself allows some ripple present on the rails to pass to the output.
Bring a dolphin to your next listening session sonidos The Lounge 5 18th July 2012 01:45 PM
Dolphin Hollow State Labs On-line Miles Prower Vendor's Bazaar 0 7th December 2009 07:01 PM
My Aleph p1.7 sounds wonderful ! zei Pass Labs 39 7th January 2007 10:25 PM
Which Aleph sounds best? Odysei Pass Labs 6 20th June 2004 04:34 PM
My Aleph sounds better! Gabster Pass Labs 32 23rd April 2002 12:43 AM
Copyright 1999-2017 diyAudio
