Aleph 5 DIY- with Dolphin sounds...Help please
Old 29th April 2013, 01:14 PM   #21
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
take your time
just enjoy in ride
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 8th June 2013, 02:52 PM   #22
george a is offline george a  Australia
Hi All
back again
well the saga continues.
Fets have been matched, to within 0.01v
All semi's on suspect channel have now been replaced..
except diodes..
the problem remains , one side is till running cold - the negative side.
No heat from mosfets, no voltage across the source resistors and -32v at the speaker terminal
still essentially back where i started after a lot of work - and some expense...
Any ideas..?
thanks in advance.
george a
Old 8th June 2013, 02:54 PM   #23
I should add that even the irf9610's have been replaced as well
george a
Old 8th June 2013, 03:44 PM   #24
Zen Mod's Avatar
time for pics
Old 9th June 2013, 05:21 PM   #25
Hi All
Back again
new developments.
In short it appears on of the lower mosfets keeps on "shorting"
In my amp i have 3 upper and 3 lower output irfp240's
the one that keeps shorting is that which is fed by a 220ohm resistor -not only on the gate but also the source-fed from one of the mpsa42 transistors (or in some iterations this appears to be a ztx450 or mpsa18).
I have managed to replace the mosfet - powerup and get 20mv offset at the speaker terminals and a sensible Vgs measured across all the output mosfets.
after a few minutes the offset shoots back up to rail voltage and the VGs dissappears...on all the lower mosfets.
Upon removal of the suspect mosfet -testing of it shows VGS back to normal whilst it is out of circuit, ie : the mosfet itself tests ok as do those still in circuit.
Replacing the mosfet back into the position from where it came causes immediate failure....
what gives.?
Zenmod- i'm not sure what photos would show as it's unchanged for the last 4 or so years...
many thanks in advance
george a
Old 9th June 2013, 05:41 PM   #26
Zen Mod's Avatar
what can I tell you , except - observe for burned parts , cold solder joints , proper mosfet fastening on heatsinks ,shorts , traces continuity, blahblah
considering that's my day job - those things are simple for me ...... so I'm having just one approach developed - start from start , go methodically , and finish ..... on end
replace small bipolars ( cheap , no matching ) , start with just one pair of mosfets in output (one upper , one lower ) , then add second then third pair
Old 10th June 2013, 01:45 AM   #27
Pardon my ignorance , but i am confused by mosfet passing Vgs test but failing in circuit....
Am i progressively destroying one mosfet after another by replacing the dodgy ones?
Electronics is not my background
Thanks in advance
george a
Old 10th June 2013, 09:43 AM   #28
Zen Mod's Avatar
funny - I'm sort of visual oriented kind of guy ........
so - we can chat till Judgment Day , and I can't give you more than generic advice , if you don't give more details
pull out all mosfets , check them all at current as in circuit , then mount back just one pair and test the amp ;
if one pair passes , add another pair .......... test ......... add another pair
if pcb isn't defective , I see no reason that amp not behave
do you have a CRO ?
use attached file for detailed info what range of measuring values to expect
Old 10th June 2013, 10:58 AM   #29
Thanks Zen mod
I'll give it another go
I did post earlier voltage settings based on the attached image , But i think they may have changed as i "seem" to zero in on the one dodgy mosfet position.
As i stated earlier the mosfets when removed from circuit and tested as though I was matching them again seemed to be working...VGS was consistent with earlier readings.
Again many thanks for the support.
Cheers
I'm also going to replace the small pcb that is home to the 3 lower mosfets to see if that has any effect.
Yes i do have a CRO, though only a single channel....
george a
Old 10th June 2013, 11:02 AM   #30
i am running out of mpsa42's can I use something like a bc546 instead?
george a
Aleph 5 DIY- with Dolphin sounds...Help pleaseHide this!Advertise here!
Bring a dolphin to your next listening session sonidos The Lounge 5 18th July 2012 01:45 PM
Dolphin Hollow State Labs On-line Miles Prower Vendor's Bazaar 0 7th December 2009 07:01 PM
My Aleph p1.7 sounds wonderful ! zei Pass Labs 39 7th January 2007 10:25 PM
Which Aleph sounds best? Odysei Pass Labs 6 20th June 2004 04:34 PM
My Aleph sounds better! Gabster Pass Labs 32 23rd April 2002 12:43 AM
