Bypass caps on source resistor (F5 example)
Old 3rd May 2013, 04:59 PM   #11
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
In this circuit bypass caps increase open loop gain, more feedback, less
total thd. The Source resistances suppress the differences between N and P
channel, so greater 2nd/3rd with bypass caps.
Old 3rd May 2013, 05:07 PM   #12
kasey197 is offline kasey197
The Dastardly Dad of Three
I'm getting less h3 with cap but more h2 - can that be due to more olg, more fb effect ?
Also the outputs here were both n channel (post 8) but I don't think that changes your conclusions any
Old 4th May 2013, 02:19 AM   #13
The one and only
I guess you would need to post the schematic, but I still expect that there
is asymmetry in the circuit being suppressed by the Source resistors.
Old 4th May 2013, 04:51 AM   #14
Your guess is right i reckon - i did not match the fets nor trim h2 at all so theres likely assymetry between top n bottom halves.
The schem - is roughly the one here with source resistors and irf outputs: The Valorous Amp - A modest aggregation of pass inspired ideas
Old 4th May 2013, 01:48 PM   #15
6L6 is offline 6L6  United States
6L6's Avatar
So is the apparent decrease in distortion a function of the cap doing something to the circuit's linearity,
or just because of the increase of total feedback?
Old 4th May 2013, 02:22 PM   #16
The one and only
The reduction in H3 is likely increase in feedback. The relative increase in
H2 is likely decreased symmetry without degeneration.
Old 3rd March 2014, 06:55 PM   #17
JZatopa is offline JZatopa  United States
I know this post is a bit old but I am curious what the outcome would be if your test circuit had a p3 to balance the distortion after the additional caps.
Knowledge is Power & Applied Knowledge is Freedom,
There is no higher religion than truth
Old 4th March 2014, 01:01 AM   #18
P3 can null out H2. So the combined effect of a P3 and bypass caps should be further reduced THD numbers.
Old 4th March 2014, 04:50 PM   #19
Thats what I was thinking. Did you end up trying that and recording the results?
Old 5th March 2014, 12:58 AM   #20
sorry can't help there - I don't have a live F5 handy. I think i caused some confusion - the title of this thread was intended for the sim example shown earlier on. The measurements were done on another push-pull amp (see post 8). Nelson in post 16 explains the results nicely and I agree completely.
All that said, i have been using the bypass caps for some time and love them. I drop the loop feedback a touch as well while i'm at it. Opens up the sound a lot.
Bypass caps on source resistor (F5 example)Hide this!Advertise here!
FS: F5 Amplifier Kit - Boards, Heatinks, Power Caps, Input Caps, RCAs, Binding Posts gripracer Swap Meet 17 6th November 2013 02:28 PM
How to calculate bypass cap across bias resistor? Henry8 Solid State 27 14th November 2010 02:20 PM
bypass caps for bypassing mylar caps? crippledchicken Multi-Way 4 27th February 2008 04:24 AM
Bypass input resistor and use a 20k pot instead? newbie23 Class D 5 13th June 2007 09:04 PM
Two cathode resistor bypass questions Sherman Tubes / Valves 17 15th July 2006 07:45 PM
