F5 Ground Loop - Need Ideas.. - Page 6 - diyAudio
Old 10th May 2013, 02:09 PM   #51
jneutron's Avatar
Originally Posted by madisonroberts View Post
Now I am now worried about oscillation. I didn't know twisting output wires together would be the right thing to do. I have read to only twist the inputs.. V- and V+ are tied together with zip ties, but not twisted..
Are these concerns related to oscillation? I am worried about my speakers now. Not that they are humming but that they might EXPLODE or something..
Yes, they also relate to oscillation. It is always best to twist together conductors which carry current to and from two objects, so that the fields are constrained as much as possible. Supply rails and transformer primaries are not immune to this.
I added to my previous post, you may wish to re-read it.
I'd worry only if your heatsinks were still getting hot. If it's oscillating, either look with a scope or substitute an 1/8th watt 8 ohm resistor at the far end of the speaker cables as a sacrificial lamb so to speak. If your speakers are in harms way, that resistor will toast.
jn
Old 10th May 2013, 03:03 PM   #52
Ok, I will go back in a twist the wires together that you recommended.
I will also borrow a friends scope and check the waveforms on output.
Of course, the heatsinks get hot just like every other F5. I just have no way of knowing what temp is too hot. Maybe I am overreacting. I mean, they arent too hot to touch or anything. I mean, I can put my face or hands on the sinks indefinately without too much discomfort whatsoever. I will look for a temperature gauge to check this out more precisely.
Are there any tests I can perform to troubleshoot the possibility of oscillation? Shorting inputs, etc..?
Old 10th May 2013, 03:20 PM   #53
basi is online now basi  Croatia
basi's Avatar
Originally Posted by jneutron View Post
Basi,
The troublesome aspect of this is the drawing puts the speaker ground current in close proximity to the input ground. Coupling between them can cause oscillation.
jn
No if they are connected like a drawn in post 24.
Greetings!!!
Less is more!!!
Old 10th May 2013, 03:36 PM   #54
jneutron's Avatar
Scope is best.
From your earlier post, I thought your sinks were getting hotter after a mod. That is why I was thinking osc.
Greetings!!!
24 is indeed a bit better. Note however, that the output wires are not twisted around the ground. That loop can induce into the input ground loop.
Remember, even though the input pair is twisted, they will still form a ground loop with the other pair at the preamp. That entire loop will be sensitive to broadcasted magnetic fields.
jn
Old 10th May 2013, 04:00 PM   #55
basi's Avatar
Scope is best.
jn
Yes i agree Output wires must be twisted and away from input like power wires.
I was only draw basic star ground sheme to help madisonroberts to resolve ground loops.There is many more tricks in audio design but that is not the question in this thread.I'm very pleased that madisonroberts resolve the problem and learn in the way.
Sorry for bad English.
Greeatings!!!
Less is more!!!
Old 10th May 2013, 04:04 PM   #56
omishra is offline omishra  India
@basi, no problem. Your intention is appreciated.
Regards.
Old 10th May 2013, 05:05 PM   #57
What I really need to do is get a thermometer and get an exact temperature reading. They sinks do feel hotter (i think) and they seem to be getting hotter faster. Although, It could be that I was not paying as much attention before this mod.
I will go in and twist the output wires as well as the AC wires to the barrier strip.
Hum is gone, I am a very happy camper.
Thanks everyone for your help!! I will keep this thread updated with anything related to my former problem.
Old 10th May 2013, 05:26 PM   #58
jneutron's Avatar
Greeatings!!!
Your english was clearly up to the task, as it certainly helped madisonroberts..
Good job.
jn
Old 10th May 2013, 08:16 PM   #59
6L6 is offline 6L6  United States
6L6's Avatar
Leave the amp on for 1/2 hour.
Then touch the heatsinks and report back how long you can touch them without it being uncomfortable.
If it's longer than 5 seconds, you are fine, if close, probably OK.
Old 11th May 2013, 08:26 AM   #60
post40
Ok here are some photos of my new isolated Main Audio (Star) Ground. It is isolated from chassis using nylon screw and nuts. All connections are in contact with each other, but are not in contact with the chassis. Main audio ground is connected to Chassis/Safety Earth via CL-60 thermistor.
The last two photos are of my grounded grid preamplifier. There is a ground bus wire connecting all the RCA jack grounds. This ground bus is connected to Chassis/Safety Earth via a small 1/4 watt resistor.
The last pic shows all those Hot wires without the corresponding Return wire, for maximisation of Loop Area.
regards Andrew T.
Sent from my desktop computer using a keyboard
ground loop Jamh Chip Amps 10 2nd November 2007 07:18 PM
Fix a ground loop! sorenj07 Digital Source 2 1st October 2007 06:39 AM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 06:46 PM
Buzzing, could it be a ground loop? JoeBob Tubes / Valves 3 14th July 2003 02:24 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Copyright 1999-2017 diyAudio
