BA-3 As Preamp
BA-3 As Preamp
Old 31st May 2014, 07:23 PM   #641
sheep is offline sheep  Canada
Can I used power BJTs in a BA-2 configuration? I would just adjust the TL431 for @1.4 volts for biasing into class B and use the BA-3 as the driver.
Old 31st May 2014, 09:45 PM   #642
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
BA-3 As Preamp
naah ......... for class B bjt you need different biasing methods ; in short - sensing htsnk temperature , to avoid gray smoke
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 1st June 2014, 05:49 AM   #643
Hikari1 is offline Hikari1  United States
Originally Posted by Hikari1 View Post
Maybe....iam running a little less bias right now too. Iam going to let it play for a couple days...maybe raise the rail voltage and bias. I can take it up to 28v rails and still have 5v of drop out. Right now iam noticing more detail and less slam and bass. But it sounds extremely good, just a bit delicate. Better detail on cymbals and piano sounds more true. But perhaps not as much drive and kick. Could be the bias and rail voltage. But iam going to give it some time before making a judgement.
OK, I've given the superreg 24hrs with the BA-3. Here's what I think:
Superreg has more detail than the LM317/337 psu. This is the most obvious difference. With the volume control maxed out on the BA-3/F5 I could hear a bit of noise from a few feet away from my 91DB efficient speakers. Quiet but there. With the Superreg I have to put my ear up to tweeter to hear anything. So perhaps the noise floor has dropped a bit.
Overall it is an improvement...small but noticeable. Makes the system a little more lively and imaging seems locked in a bit better. It seems to have lost a little tonal density...sounds a little thinner, just a little. This may be due to tighter bass or less bass bloom. "Clean" is the word I would use. Seems like some of the bass and "slam" is returning as it runs in. It seems to be loosening up a little.
Also, I was running 30V rails w/the LM317/337 combo. Now I am running 25V rails due to the greater dropout of the superreg (5V or greater is recommended). I am guessing this is kind of a step backwards (I assume more rail voltage is better) then a step forwards with the superreg.
Should all you guys w/LM317/337 regs on your BA-3 ditch them for the superreg? It's your call. I am happy, glad I did it.
Old 1st June 2014, 12:46 PM   #644
Zen Mod's Avatar
BA-3 As Preamp
shunt is my poison
Old 1st June 2014, 02:01 PM   #645
6L6 is offline 6L6  United States
6L6's Avatar
BA-3 As Preamp
If I swap a transformer from one project to another I could have enough overhead voltage to try a shunt in the BA-3... I wonder, that would be interesting...
Old 1st June 2014, 02:12 PM   #646
Zen Mod's Avatar
BA-3 As Preamp
Originally Posted by 6L6 View Post
If ...
http://www.diyaudio.com/forums/pass-...ml#post1466712
while we are there .........
Originally Posted by Zen Mod View Post
(talking about ........ once I mounted watering can instead of TV antenna on the roof , naturally with antenna cable connected to it ........ just to tease my neighbors .......... they have strange look few days ............ )
Old 15th June 2014, 06:36 PM   #647
Bengali is offline Bengali  United States
With preamp off, should I be able to turn P1 P2 resistance to zero?
Negative rail, lowest on trimmer measures 100ohms. I ran into issue, neg rail
On power up measures -24v the becomes -5v. I pulled the board out and going through
All the part vaues and shorts.
P1 and P2 are 1K, Im using fairchild for Q3 Q4
Old 15th June 2014, 07:20 PM   #648
Sorry, measured wrong end of resistor
What resistance should I measure at R3 if P3 100ohm is set midway?
Old 15th June 2014, 07:51 PM   #649
Zen Mod's Avatar
BA-3 As Preamp
psu common for both channels ?
Old 15th June 2014, 08:51 PM   #650
R3 and r4 should have same resistance across them when p3 is midway.
What are you using for a psu? If you dont have 24v positive and 24v neg out of the psu you have issues. Dont hook it up to the board.
BA-3 As PreampHide this!Advertise here!
ADA Audio Design Associates Millennium - preamp - MILLEN-2000+BA - control center Jimmy154 Swap Meet 1 16th November 2012 05:19 PM
BA-C buzzforb Pass Labs 60 23rd October 2011 08:58 PM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Ba-1 Rembulan Pass Labs 0 15th May 2009 01:09 AM
