BA-3 As Preamp
BA-3 As Preamp
Old 24th April 2013, 04:04 PM   #21
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
BA-3 As Preamp
more voltage , more oohmps ;
however , don't go bellow 24 and certainly not more than 30V , without cascoding
in your boots , I would go with 24 , heavily ( read - shunt ) reg-ed
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th April 2013, 04:10 PM   #22
PKI is offline PKI  United States
PKI's Avatar
BA-3 As Preamp
But if it is not the same rail as F4, it doesn't matter I can go any way from 24 to 30. It wil be a separate transformer, so what is the best 28V? The only thing is: remember distortion curves Pa posted in his paper? More voltage less THD, right?
He never makes labels and legends for his graphs! Bad I am reviewing papers in different journals, I would change it! :-) :-)
Old 24th April 2013, 04:14 PM   #23
Zen Mod's Avatar
BA-3 As Preamp
I just said - I would go with 24V , regged , as general purpose preamp
28V sounds fine , if F4 is in combination
nice compromise between possible swing and input Jfets dissipation
Old 25th April 2013, 11:47 AM   #24
bnorrish is offline bnorrish  United States
bnorrish's Avatar
Madisound is having a sale on ClarityCaps. There are several line SA, ESA, MR. How critical a part is this? Anyone think you will hear a difference? 10 mfd SA is ~$10 and they go up from there.
Old 25th April 2013, 12:22 PM   #25
Zen Mod's Avatar
BA-3 As Preamp
pick your own poison
whatever you do , try MKC ( polycarbonate ) bypass
me , as stubborn , will use Elna Silmic + MKC
in fact - would not use any cap there - would make a servo or something , to keep it DC
Old 25th April 2013, 10:52 PM   #26
bnorrish's Avatar
Why would you? Better sound or other?
Old 25th April 2013, 11:19 PM   #27
6L6 is offline 6L6  United States
6L6's Avatar
BA-3 As Preamp
Yes, you will likely hear a difference in caps. It's a fantastic place to experiment and hear what different caps sound like.
Silmic and MKC would probably be awesome, if you can find the Wima MKC. Clarity Caps are very good. Again, use this place to experiment/educate yourself as to how things sound.
ZM - Can you accept PayPal yet to sell Shunty?
Old 25th April 2013, 11:37 PM   #28
bnorrish's Avatar
Shunty? Serbian PSU good for BA-3?
Old 26th April 2013, 01:05 AM   #29
Zen Mod's Avatar
BA-3 As Preamp
you bet
Old 26th April 2013, 11:04 AM   #30
Itsmee is offline Itsmee  England
Itsmee's Avatar
I'd recommend a Shunty if you can get one; if you can't, you could make make a good sounding regulator using a standard 2 device constant current source and a TL431 configured as a high current shunt regulator - see the data sheet - you could also swap the BJT for a FET - if you do, don't forget to add a 220R gate resistor.
Add a pre reg if you need to drop some voltage, this will also help to reduce the power dissipation in the shunt.
You can flip the symmetry of the pre reg and constant current source for the neg rail, but not the shunt, which won't make a difference to the performance, but some people can get a bit overly anal about symmetry.
BA-3 As PreampHide this!Advertise here!
ADA Audio Design Associates Millennium - preamp - MILLEN-2000+BA - control center Jimmy154 Swap Meet 1 16th November 2012 05:19 PM
BA-C buzzforb Pass Labs 60 23rd October 2011 08:58 PM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Ba-1 Rembulan Pass Labs 0 15th May 2009 01:09 AM
