@angrypat
my incompetent brain says:
- 2 x (100mA max Mosfet bias + 8 mA Jfet bias) = 216 mA current draw per rail from BA-3 front end...say 250
- R3 filters the AC and you can choose what fits the load: say 10 Ohms - gives 2.5 volts drop and 0.7 watts dissipation
- better use dual secondaries 2x(20-24)V xformer no centre tapped
- test with fuse and current limiter (e.g. low wattage light bulb) in place
Dual/Bipolar LV-Reg
Dual/Bipolar LV-Reg
For starters: I'll use a Ultrabib...
Hi!
I'm approaching in on the continuation of my BA-3.
I'll power it with an Ultrabib, recommendation is to "allow 50-150mA extra"...
[Edit: Just reading ozorfis post saying I'd need 250 mA / rail, while Dennis says 45 mA... ]
What difference would it make wether I'd go smallish (total of 100 mA / Channel) or biggish (200 mA / Channel)?
I'm [edit: was] pretty sure everything in-between would work, but …
(ok, I know I should go and test it myself, but sometimes I'm :lazy:, sometimes I'm just hesitant , and maybe this is knowledge so easy as a this/that because so or otherwise?)
But but but, the
Hi!
But but but, the
when shunt reg is in the case, I'm usually allowing 25-50% of headroom, that being difference between programmed reg current and loading circuit current
if reg is made properly, no difference in sound between 25% and 250% headroom, under condition that load is pure A Class thingy (not being able to overstep Iq)
Depends on the bias you like to run and if you refer to one or two channels.
Stock setting according to Papas article:
2 (channels) x (45 (Mosfet bias) mA + 8 (Jfet bias)) = 106 mA
I like to run my Mosfets at 100 mA Bias hence the higher figure.
ah, cool, thank you! (I had it right, Woohoo! )
and then
I probably didn't quite understood this, please ignore if completely off: Do you let the resistor decide wether it's closer to 25% or 50% or is there a deeper understanding that leads you to either number? (I'd go for my favorite colour codes, hahaha)
and then
easy; example:
stage is having Iq (quiescent current) of 20mA
heat is nothing (hottest part in reg asking for just small heatsink), so programmed current of reg is , say, 70mA (that being headroom of (70/20)= 350%
second example:
stage is having Iq of 100mA
current becoming an issue, so reg's programmed current being , say, 135mA
that's 35% of headroom
pick figure which you want, being aware of dissipation of every part; two most critical parts being CCS main transistor and Shunt transistor (transistor being mosfet or bjt, irrelevant)
second example:
Start here. Any other questions, just ask.
https://www.diyaudio.com/community/threads/the-ba-3-as-preamp-build-guide.258022/
Pass DIY Addict
Joined 2000
The original output devices for the BA-3 front end are 2SJ313 and 2SK2013, matched at 20v and 45mA. These devices, though, have been discontinued by Toshiba. A few members here may still have some inventory of these parts, so check the Swap Meet section if you are seeking original parts.
Edit: I believe you can substitute the P-channel 2SJ313 with part number FQP3P20 and substitute the N-channel 2SK2013 with FQP3N30 without any appreciable difference in outcome. It also appears that the replacement parts are now in End-of-Life stage as well. Not sure which parts are appropriate for an alternate to the alternate... I'm sure someone else can make a recommendation for you.
It's been a while but I believe a BA-3 FE channel draws ~45mA and I set the BIB (not the Ultra) to sink ~100mA. The BIB drops ~7V so in your case the output after ratification and losses at the BIB would be around 26V, which would be good. I know others have used this same setup (BIB->BA-3 FE) with success. It would be appreciated if someone would confirm my numbers.Transformer requirement...
Hi friends
Can the BS-3 run on a PSU consisting of a 2x24V 100VA transformer into a Ultra-bib?
And, how much current-draw should I aim for?
Asking because I got an offer for the trannies, Ultrabibs are already in the plan...
Thank you
david
- BA-3 As Preamp
