BA-3 As Preamp
BA-3 As Preamp
Old 10th October 2017, 04:53 PM   #1241
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
BA-3 As Preamp
wdecho , will you post exact schmtc of your BA3 FE specimen ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th October 2017, 05:04 PM   #1242
Zen Mod's Avatar
BA-3 As Preamp
ref. to enclosed sch
decrease R5 until you are satisfied with gain
68R there will give almost 3db of increase
51R will give almost 5db
Old 10th October 2017, 05:14 PM   #1243
wdecho is offline wdecho  United States
BA-3 As Preamp
Thanks Zen, will do. I thought that R5 is one of the resistors to change. Just a solder slingers guess.
This morning I installed another op-amp in my op-amp phono pre with 2 db more gain and the BA-3 has enough oomf with enough volume right now but it would be nice if I can use it with my J-fet phono pre as well. I think I will go with 68 ohms to start. Right now with a higher gain phono pre the sound has more authority with my F4. The F4 is one of, if not, my favorite amplifier among the 6 finished FW clones I have.
About to forget, same schematic used.
Old 13th October 2017, 07:17 AM   #1244
R.I.P.
Tack a temporary 220r in parallel with the existing 100r to get ~ 68r
and listen/measure.
Then change the temporary 220r to a 130r to get ~ 56r
These could be wired in with a dip switch to give switchable variations if you need that.
regards Andrew T.
Old 13th October 2017, 11:14 AM   #1245
BA-3 As Preamp
Many thanks guys.
Old 4th December 2017, 05:42 PM   #1246
broennimannrainer is offline broennimannrainer
I have built this preamp several years ago. Some uf of PPs in the output and was not so impressed.
Now I revived it. First finding: the nominations of P1 and P2 in the schematic are reversed. Had quite some fun.
With Silmics in the output the preamp is overly polite. With Nichicon FG, KZ and biplolars it is much more fun but still a bit recessed.
I changed the gain according to Zenmod and Andrew - and everything is fine now. Very open and dynamic.
Many thanks.
Old 8th December 2017, 10:56 PM   #1247
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
I really should be working right now, but I could not resist
Version b of my boards arrived after almost 2 months in customs. The crisis is now messing with our hobbies as well...
Anway...
They seem to bias up nicely, and the FQP pairs seem very close without any matching.
Here is some porn
BA-3 As Preamp-img_20171209_001340-jpg
BA-3 As Preamp-img_20171209_011021-jpg
Too many projects... so little time...
Old 8th December 2017, 11:05 PM   #1248
Zen Mod's Avatar
BA-3 As Preamp
intend any heatsinking on them ?
Old 8th December 2017, 11:27 PM   #1249
dimkasta's Avatar
Yeah they are going on a 10mm aluminum bottom plate
Old 7th April 2018, 12:06 AM   #1250
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
BA-3 As Preamp Send a message via Yahoo to vdi_nenna
Anyone know how I can simulate the load the ba-3 preamp circuit has on the power supply? Can a resistor be used?
I have an AN-0512 Antek 12v-0 12v-0 secondary wired in series for 24v. Im getting odd reading with no load on the regulated power supply. The reg power supply manual says to use a load to get proper readings.
It's an LM317/LM337 based regulator.
I want to test the power supply before connecting it to the ba-3 preamp circuit. What value resistor, if any, can be used?
Vince
I build, therefore I am.
BA-3 As PreampHide this!Advertise here!
ADA Audio Design Associates Millennium - preamp - MILLEN-2000+BA - control center Jimmy154 Swap Meet 1 16th November 2012 05:19 PM
BA-C buzzforb Pass Labs 60 23rd October 2011 08:58 PM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Ba-1 Rembulan Pass Labs 0 15th May 2009 01:09 AM
