A guide to building the Pass F4 amplifier.
Old 29th March 2014, 10:46 PM   #191
debk is offline debk  United States
debk's Avatar
F4 amp with Purpleheart front panel, illuninated power switch, and purple LED for each board.
Now to build the other channel!
Debra
Old 30th March 2014, 04:09 PM   #192
willamp is offline willamp  United States
willamp's Avatar
Nice!
Good to see something besides aluminum.
I see it's in the kitchen. Warming up dinner with it? It should be good for that.
Old 2nd April 2014, 08:14 PM   #193
bjorgens is offline bjorgens  United States
contemplating a similar setup to what debK notes above (source >> preamp >> DHT SET amp >> F4) except that my Bottlehead paramount monoblocks are using 300B output tubes in lieu of her 2A3 or 45s.
I'm not smart enough to know whether the higher output of the 300B amp (~9watts) relative to a 2A3/ 45 amp is material here or not.
of note, I intend to build the stereo 25WPC version of the F4... at least for now
would appreciate any thoughts on the subject...thanks!
Old 7th April 2014, 09:59 PM   #194
debk's Avatar
I have both F4 amps built and working in my system. First I tried it with the 45 amp. While it sounded ok the 45 amp was not able to drive the F4 well enough to take advantage of it. It was slightly louder, but not much of a difference.
Next I switched out the 45 amps for my 2a3 amps and the difference was remarkable. More volume than I need and still sounds very much like a DHT amp. The F4 lends virtually no coloration to the sound. I think I will leave it in this configuration for a while
Source-->preamp--->2a3 amp--->F4
I am sure it will also work very well with a 300b amp, but I have not tried it. Mine are currently torn apart to be reworked.
Like a tube amp the F4 takes a bit of time to warm up and sound it's best.
All the listening was done using the same source: Sota Sapphire, Kiseki Purpleheart cartridge, Bob's devices SUT, Bottlehead Eros phono stage, Nora Jones LP
Debra
Old 7th April 2014, 10:07 PM   #195
debk's Avatar
These amps put out a bit of heat. A new concept, heat your home with music
Next I am going to build a Pumpkin/Shunty preamp to try
Old 7th April 2014, 11:37 PM   #196
willamp's Avatar
Yes, it takes my F4 2hrs of warm up to get to it's full potential. For the longest time I thought it was alcohol related but then, with the help of friends we concluded it was truly thermal. After a couple of hours the entire chassis/heatsinks are at about 50 degrees C. It truly sounds it's best from that point on. A little inconvenient sometimes but worth the wait.
Old 8th April 2014, 03:45 AM   #197
Thanks Debra... Appreciate the info!
I should have parts in next couple of days, so we'll see how this goes.
I presume you fabricated cables for DHT outputs >> F4 inputs. Any sage wisdom?
Bryan
Old 8th April 2014, 06:50 AM   #198
valvesound is offline valvesound  South Africa
valvesound's Avatar
I have had the thoughts cos by the time the amp is warm I am also
Old 8th April 2014, 10:40 AM   #199
debk's Avatar
Bryan
I used a cable with RCA at one end and banana plugs at the other.
Put a resistor across SET amp output
Old 9th April 2014, 12:18 AM   #200
willamp's Avatar
+1 ��
A guide to building the Pass F4 amplifier.Hide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 986 29th July 2017 07:20 AM
A Concise Guide to the Published Amplifier Circuits of Nelson Pass rsdio Pass Labs 50 1st May 2017 04:56 PM
My,PASS ALEPH J and f4 xr000 Pass Labs 1 25th December 2009 04:20 AM
Idiotīs guide to building Pass amps? judge Pass Labs 3 20th December 2004 12:33 AM
