A guide to building the Pass F4 amplifier. - Page 2 - diyAudio
Old 18th April 2013, 07:49 AM   #11
buzzforb's Avatar
Originally Posted by bnorrish View Post
Interesting - board is $7. I have not looked the the BAs that closely. Anyone post one of those to make standalone preamp? Need to add some sort of attenuation for volume. I am sure there are a few other details.
Build two F4's and go balanced with BA3 and you have something very nice. Has P3 to adjust sound to your liking. No feedback is special sound.
...Shape the sound , Man!
Old 18th April 2013, 09:39 AM   #12
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Fugly! tutorial
(except fact that 4x33mF is sissy cap bank , in my book )
and , yes - if you turn that tech. bottom plate upside down (comparing to present position) , you'll have place for screw heads underneath
in way like you made it , screw heads are bottoming to regular bottom plate
there is a way to save what you made , without flipping that plate and making new holes - take longer M4 screws (4 pcs , which are holding tech. plate to side brackets ) , screw them to side brackets with 2 screw nuts on each , then put tech. plate on them , screw it with screw nuts
that way you'll have 2 screw nut height of clearance between tech. and bottom plates
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 18th April 2013, 09:41 AM   #13
bnorrish's Avatar
Originally Posted by 6L6 View Post
Like anything, put your selector switch then your pot/stepped attenuator before the input of the gain stage. Easy!
PSU could be done a million different ways, choose your preferred flavor.
I would be happy to help, if you would like a nudge in the right direction.
Order complete - F4 and BA3 front end boards.
Old 18th April 2013, 10:06 AM   #14
buzzforb's Avatar
You can go naked with f4 if using Ba3 FE.
Old 18th April 2013, 10:19 AM   #15
Originally Posted by thor61 View Post
Really great pics and write-up ! I have a heat-sink question as I have not drilled my sinks yet. Could someone tell me the distance from the bottom for the mosfet bolt holes ? See pick Attachment 343260
1/3 up from the bottom is a nice place to start.
Old 18th April 2013, 11:12 AM   #16
bnorrish's Avatar
It sounds that good that I would want to get naked. Sorry - could not resist. Not sure I quite follow. I would be using with Pearl 2/TT, CD and Sonos. If I only had a DAC or digital source I could go naked - just use the BA3 board as is between the source and F4. Use source to attenuate.
Old 18th April 2013, 11:15 AM   #17
buzzforb's Avatar
Dropping the Jfet FE on F4. Basically complete BA3. You can wire F4 with switchable input so that it can be used as plain F4 or Naked F4.
Old 18th April 2013, 01:23 PM   #18
6L6 is offline 6L6  United States
6L6's Avatar
It's quiet and I had it on hand.
The next DIYaudio PSU circuit board will be able to hold (8) caps with 35mm diameter - Once those are available I will make a big Brutus cap bank.
Papa uses (8) 15,000uf, so he must be sissy as well? LOL!
Yes, I suppose it is upside-down...
However, there are no holes drilled in it except big one for transformer, so flipping the sub-plate will actually be easy. I need to take it apart anyway to attach the rest of the chassis pieces.
Old 18th April 2013, 01:26 PM   #19
6L6
Fantastic guide !!!! I will soon be assembling my Ba3B - F4 and now I have the model !!!! Thank you
Old 18th April 2013, 01:53 PM   #20
What is the ETA for the next Diyaudio PSU board ? Here is a link for the one I have, it has the thermistor board mounted. Please tell me what you think.... See link > CRC Power Supply PCB Terminal Blocks Thermistor Are Included | eBay
An illustrated guide to building an F5 6L6 Pass Labs 973 16th June 2017 08:50 PM
A Concise Guide to the Published Amplifier Circuits of Nelson Pass rsdio Pass Labs 50 1st May 2017 03:56 PM
My,PASS ALEPH J and f4 xr000 Pass Labs 1 25th December 2009 03:20 AM
Idiot´s guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
Copyright ©1999-2017 diyAudio
