A guide to building the Pass F4 amplifier.
Old 26th July 2013, 04:52 PM   #101
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Silmic , bypassed with 10n-1uF MKC
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...Đ by Mighty ZM
Old 29th July 2013, 09:42 AM   #102
valvesound is offline valvesound  South Africa
valvesound's Avatar
Thanks Buzz. I found these "http://docs-europe.electrocomponents.com/webdocs/10f6/0900766b810f629a.pdf" available locally...they are not cheap though. I have read that they are superior to "normal" electrolytic's in audio frequency coupling applications so maybe worth a try.
Old 29th July 2013, 09:47 AM   #103
buzzforb is offline buzzforb  United States
buzzforb's Avatar
You just have to try. Elna RFS is what Pass uses and is available from Digikey.
...Shape the sound , Man!
Old 29th July 2013, 04:46 PM   #104
henryve is offline henryve  South Africa
henryve's Avatar
Willem
I find it works much cheaper in the long run to order from Mouser or Digikey. I usually build up my orders till they are more than $200 so that I get the shipping for free. I also order more of each to build up my local stock to save on later having to order. For example I order 50 of the Dale resistors each when I have to order a value. RS here locally has been useless of late.
Old 30th July 2013, 07:47 AM   #105
valvesound's Avatar
Hi Henry.....yes RS was OK to use for small quantities before they started charging for shipping. Now one has to build up a bit of an inventory before ordering from them too. Electrocomp locally are also Farnell agents so maybe an option these days.
Old 13th September 2013, 04:57 PM   #106
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
Default Photobucket pics aren't showing
Photobucket pics aren't showing up today?
Currently listening to F4 or F6/w curve matched SemiSouth outputs
Old 13th September 2013, 05:10 PM   #107
6L6 is offline 6L6  United States
6L6's Avatar
Dagnabbit... it hit the bandwidth limit again. It resets in a couple days.
Old 30th September 2013, 11:14 PM   #108
udailey is offline udailey  United States
Passive Aggressive
6L6 Maybe try Picasa. Unlimited bandwidth.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 30th September 2013, 11:28 PM   #109
6L6's Avatar
Picasa would be fine fo anything new, but the 1000 or so links to images at photobucket won't survive a straight transfer...
I fixed it for a year with the application of some $$.
Old 30th September 2013, 11:36 PM   #110
Einric is offline Einric  United States
Einric's Avatar
I used Pannasonic FM 220uf bypassed with Vishay MKP1837 .01uF.
A guide to building the Pass F4 amplifier.Hide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 986 29th July 2017 06:20 AM
A Concise Guide to the Published Amplifier Circuits of Nelson Pass rsdio Pass Labs 50 1st May 2017 03:56 PM
My,PASS ALEPH J and f4 xr000 Pass Labs 1 25th December 2009 03:20 AM
Idiotīs guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
