Single Primary Transformer wiring help
Old 17th April 2013, 04:38 PM   #1
Hikari1 is offline Hikari1  United States
Default Single Primary Transformer wiring help
I am almost ready to hook up my F5 PS to 120V (US).
My transformer has a single primary. I've looked at the Pass PSU schematic which shows wiring for a dual primary transformer. It's got me confused on to how to hook up my single primary transformer.
Is the attached diagram the appropriate way? My transformer has on black primary (I assume it is LIVE) and one white primary (I assume it's N).
Let me know what you think. Thanks.
Old 17th April 2013, 05:43 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
that left pic is ok , even if I'm slightly confused with two black elipses ; if they're thermistors , you need just one
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 17th April 2013, 06:16 PM   #3
Just need a thermistor on the LIVE wire to the transformer? Not the Neutral wire?
Old 17th April 2013, 06:26 PM   #4
Mooly's Avatar
The primary circuit is just a series circuit and so the thermistor could go in either side electrically. Conventionally it would go in the live side although the neutral side offers the dubious advantage of the thermistor not being "live" when connected to a correctly polarised mains outlet.
Old 17th April 2013, 08:23 PM   #5
6L6 is offline 6L6  United States
6L6's Avatar
Just use one thermistor, after the switch, on the Live side of the primary.
Old 17th April 2013, 09:33 PM   #6
Great. Thanks guys. More dumb questions coming soon. I promise.
Old 17th April 2013, 09:51 PM   #7
6L6's Avatar
The ONLY dumb questions are the ones not asked.
Old 18th April 2013, 06:44 AM   #8
That's good to know. Because I haven't even started asking about wiring the rectifiers yet.
Old 18th April 2013, 07:12 AM   #9
Zen Mod's Avatar
Audio Electronics, Second Edition: John Linsley Hood: Amazon.com: Kindle Store
Old 18th April 2013, 08:28 PM   #10
6L6's Avatar
This might help -
Click the images to make them the proper size, and the text more readable.
This shows the INPUT edge (from the diode bridges)
Here you can see the bridges with the wires attached from the transformer secondary. Remember that the green attached to a bridge must have continuity with the blue attached to the same bridge. (As it's the 2 ends of the same piece of wire)
Single Primary Transformer wiring helpHide this!Advertise here!
Can MOV (varistors) be wired to each primary in a universal dual-primary transformer? fualcr Power Supplies 2 11th November 2012 01:34 AM
F5 Single Primary Transformer NV&H Pass Labs 15 28th June 2009 09:57 PM
Can I use a single primary 120V transformer with 240V? hershann Power Supplies 6 24th January 2008 02:02 PM
