Mistakes you Learnt from! (might be helpful for beginners) - Page 3 - diyAudio
Old 14th April 2013, 12:15 AM   #21
Originally Posted by HIPCHECK View Post
5. Get a Variac, Bulb Tester, Fuse board, and make a test rig.
Can you (or someone) give some guidance around what would be a good variac? Any particular specs or brand? Thanks.
Old 14th April 2013, 02:48 AM   #22
Andersonix's Avatar
It is rumored that Steve at ApexJr still has several variacs on his shelf, but not listed on the website?
Old 14th April 2013, 07:02 PM   #23
henryve is offline henryve  South Africa
henryve's Avatar
Get a set of Spotting Drills for drilling holes position perfect. When countersinking into Aluminium, use a Hole-type Countersink bit. I have tried all the tricks with the Fluted types but they still chatter.
Old 14th April 2013, 07:50 PM   #24
pinkmouse's Avatar
Don't try to catch a hot soldering iron that's falling off the bench...
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 14th April 2013, 11:35 PM   #25
Telstar is offline Telstar  Italy
Originally Posted by sakellogg View Post
setup 2 meters when you are testing for voltage and current. use one for volts and one for current.
ive killed parts before, forgeting to swap back using 1 meter.
How did this happen? I can switch easily from DCV to A on my Keithley...
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 14th April 2013, 11:37 PM   #26
Originally Posted by AndrewT View Post
Multi-meter probes with exposed metal.
Insulate the probe tips so that only the last 1mm is exposed to accidentally touching other components.
Great advice. I have to do this for where the miniclips cant enter
I'd add to solder resistors with more space over the pcb so the miniclips would fit and stay anchored
Old 14th April 2013, 11:39 PM   #27
Originally Posted by Danger Mouse View Post
double or triple check correct position of your parts at PCB
For me, double check parts orientation BEFORE soldering them
Old 15th April 2013, 02:54 AM   #28
1. Build your power supply first. Test it, using a bulb tester and confirm your "no load" voltages.
2. Build one amp channel next. Ground the inputs for your first tests. Do NOT test with an expensive loudspeaker system. Connect it to the power supply and test. Use the bulb tester at first. (Read, don't blow out TWO channels of an amp, just because they both have the same wiring error!)
3. Build the second channel. Wire it the same as the first. Connect and test.
4. Don't tell you're "significant other" how much you are spending on transformers, heatsinks and your F5X projects......!!
Old 15th April 2013, 07:12 PM   #29
AntonTR is offline AntonTR  Russian Federation
Measure twice, cut once... And... Hundred times of regrets!
Sorry for offtop but sometimes it is most real thing that happens)
Best regards, Anton
Old 15th April 2013, 07:37 PM   #30
Cubdriver's Avatar
On the Flukes (handhelds) that I'm used to using, to measure current you not only have to switch to the 'current' setting on the selector switch, but you must also swap the positive lead from the 'V-ohms-diode check' input to the 'A' input. In this configuration, the meter is basically a dead short lead to lead, and (in my case anyway) fused at 10A.
If, without paying enough attention, you measure current and then later switch to voltage and go to take a measurement without swapping the lead back to the V jack, you wind up putting a short that can carry 10A across whatever you're trying to measure the voltage of. Something then frequently goes 'poof'. It may be the fuse in the meter, or it may be something in the circuit you're measuring that doesn't like short circuits. I could say I've never done that, but it would be a lie.
I'm guessing that your Keithley doesn't require the input to be swapped for current measurements. Is it a bench meter, rather than a handheld?
-Pat
Cyrus 3 Amplifier Component Mistakes? hexagonsun Solid State 10 1st December 2009 07:34 PM
First build - Common mistakes Hugo82 Multi-Way 23 17th March 2009 09:16 PM
Learnt a lot! Time for an introduction... Ronmeister Introductions 5 28th December 2008 01:04 AM
PCB Mistakes/Optimization(?) OmarAvelar Chip Amps 19 10th April 2007 11:01 AM
LM3886 Plans, any mistakes? jkostans Chip Amps 7 4th January 2007 11:54 PM
Copyright 1999-2017 diyAudio
