Beginner's Build Guide: Pearl II - Page 9 - diyAudio
Old 14th May 2013, 12:46 AM   #81
Ok, rare strait forward question: what should the voltage be coming out of Q1? I did a quick comparison of the two boards, and was able to trace back a difference between the two to Q1, with the working board having just under 20v leaving, and the other zero. I replaced q1 on the non working board, and now get just under23v leaving it, which leads to a consistent 3v difference from then on between the two boards. Can someone tell me which is correct? Thanks as always.
Old 14th May 2013, 01:26 AM   #82
bnorrish's Avatar
Per Wayne's voltage diagram, it should be around 20.2v.
Old 14th May 2013, 02:11 AM   #83
6L6 is offline 6L6  United States
6L6's Avatar
About 20V there is correct.
There are 13 voltages on the schematic - are all thirteen of them 3 volts higher? Check the 0 volt points first, the top of R13 and the top of R17
Old 18th May 2013, 06:35 PM   #84
Hi Folks,
It took a while to get the two boards stabilized, but now that seems to be the case, so I checked voltage. What follows is Wayne/pcb #1/ pcb#2
Input R9: 20.2/22.6/19.7 (two boards noticably different, can't see why)
Output R9: 10.1/7.2/7.6 (two boards similar, but noticeably different from Wayne)
Output Q3: 9.4/7.1/7.5 (ditto)
Input R24: .01-.04/.06/.06
Drop across R6: 1.5/1.5/1.5
Output R6: 21/20.4/20.3
Input R13: 0/0/0
Input Q10: -23/-22.5/-22.6
Input R27: -22.3/-21.9/-22
Output Q11: -23/-22.5/-22.6
Input R17: 0/0/0
I am getting +- 23.6 at the output of the resistors at the regulators.
So, the area that is most different is around Q1 and Q3, and inconsistently so. PCB #1 has voltage two high going into Q1, but they both have voltage too low leaving.
Any thoughts? Thanks again for your time. If there is anything I can do to clarify, let me know.
Old 18th May 2013, 08:19 PM   #85
bnorrish's Avatar
Hi Folks,
Is R5 correct on the board with 22.6?
My readings were similar to yours until I bumped up R21-R24 to 20 ohms, on advice from Salas.
Old 19th May 2013, 12:08 AM   #86
I checked r5, it is fine, but I do think that is where the problem is. There is minimal voltage drop across it on the problem pcb. Possibly the solder for q1? It looks ok, but barring other ideas I may resolder q1.
Old 19th May 2013, 12:40 AM   #87
bnorrish's Avatar
Maybe Q1 is no good. Any spare ZTX450s?
Old 19th May 2013, 12:55 AM   #88
Just tried! No change. Odd.
Old 19th May 2013, 06:14 PM   #89
Ok, progress--tested around r7, something was obviously wrong (got same voltage both sides), replaced it, and that sorted the first voltage anomaly noted above--now I am getting around 19.6 v out of q1 on both boards. I will try 20 ohm resistors as suggested when I get them (hello, mouser).
One odd thing--I tested the r7 I pulled from the board after replacing it, and it tested out ok. The problem must have been the solder, I guess? I don't know.
Old 19th May 2013, 11:31 PM   #90
bnorrish's Avatar
Big ground plane on the Pearl 2 - a little extra solder juice is needed, especially on the ground side of the big caps.
diyAudio F5 Build Guide Jason The diyAudio Store 26 19th March 2017 08:39 PM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
Guide to build Hypex Modules souldriver Class D 85 16th July 2011 07:29 PM
FS Pass Pearl II board and JFET set 1MOR Swap Meet 1 26th February 2011 02:52 AM
Beginner's Gainclone guide Nuuk Chip Amps 45 1st July 2003 07:45 AM
Copyright 1999-2017 diyAudio
