Arch Nemesis - High voltage version - Page 2 - diyAudio
Old 28th March 2013, 11:09 PM   #11
The one and only
Nelson Pass's Avatar
I have spent some time with this, and I can tell you about a couple of
issues. The SITs that I've been able to play with required a seriously
negative Vgs in order to bias the part at the relatively low currents and high
Vds voltages, in many cases near the Gate-Source diode breakdown voltage
of the part.
On top of that, the Gate leakage current gets higher at these Vgs figures.
In the end, SITs are a good emulation of triodes at the lower voltages and
higher currents needed by speakers, which is nice. If you really want to use
SET transformers, you are really probably better off with tubes.
Old 31st March 2013, 09:07 AM   #12
oon_the_kid's Avatar
Hi Nelson,
Thanks for the inputs. I wasn't really thinking of the SITs. Last I checked it was made of unobtanium unless one is a relative of a certain Nelson Pass. I was looking at more of the bipolar transistor, particularly the ztx series.
The other issue I was thinking about is the additional voltage generated by the transformer coil and if could damage the transistor. So do you think it would be wise to put a diode across the transformer?
Oon
The Arch Nemesis jan.didden Pass Labs 16 19th April 2016 01:24 AM
New Nelson Build dubbed the Arch Nemesis vizion Pass Labs 135 14th December 2013 12:32 AM
Hifonics Nemesis NX-400 low rail voltage Mote Car Audio 50 19th October 2011 07:40 AM
Copyright 1999-2017 diyAudio
