Amp Camp Amp Mod
Amp Camp Amp Mod
Old 21st March 2013, 01:37 AM   #11
Loudthud is offline Loudthud  United States
Loudthud's Avatar
Yes, Source current for Q4 comes through the 56 ohm feedback resistor. The voltage drop across that resistor gets hidden by the gate-source voltage of Q4 such that the gate and output are at zero volts. R9 has to be adjusted to null the output.
Old 21st March 2013, 01:43 AM   #12
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I like it, but wonder sbout the influence of the input. Ultimately it does give you more gain for feedback,which is important and helpful.
...Shape the sound , Man!
Old 21st March 2013, 03:02 AM   #13
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Amp Camp Amp Mod
see buzz - again F5/F6/toob - like feedback
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 21st March 2013, 03:13 AM   #14
buzzforb's Avatar
Round and round we go.
Old 21st July 2013, 10:48 PM   #15
VoltSecond is offline VoltSecond  United States
VoltSecond's Avatar
Default Why no 10K between R5 and R7
I was browsing around and found this amplifier. I'm curious, Why no 10K between R5 and R7? It looks like the gain from Q3 is completely swamped out by the bypass cap. I only browsed ~30 of the 100+ pages of comments trying to see if this has already been answered. I'll look for a "summary site," off to do yard work!
I like the use of switching supplies for power. A small, damped common mode choke and a small bead on the power results in a very quiet supply. The only problem I've run into with switching supplies is oscillations under certain capacitive loads. This is usually fixable with a zobel (inductor in parallel with a resistor) in the series with the switching supply.
Unplug it, discharge it, and measure it (twice) before you touch it.
Old 21st July 2013, 10:51 PM   #16
Zen Mod's Avatar
Amp Camp Amp Mod
you can try it , and certainly expect different THD spectra , comparing to original
maybe you'll like it , maybe not
Old 6th October 2013, 10:51 AM   #17
dragonweed is offline dragonweed  Hungary
Banned
Finally....I've tried the suggested 10kohm resistor mod between R5 and R7, the THD value dropped to almost half, but it effectively killed the "magic" of this amp, the speed, dynamics, and punch present with the original circuit is all gone.... So much about the differences between theory and practice. Nevertheless thanks for your suggestion. (I used a switch to bypass the 10k, so the comparision could be made almost immediately)
Old 6th October 2013, 11:29 AM   #18
Zen Mod's Avatar
Amp Camp Amp Mod
C2 is with reason connected to R7,R5 node - to modulate gate of upper mosfet
introducing resistor in between transforms mu-like operation to common CCS , ACA becoming ordinary SE amp
Old 6th October 2013, 11:46 AM   #19
Banned
Yes, I was aware of that fact from other Pass designs..... now I've replaced the 10k resistor with a pot, so you can "transit" between the two modes. For my ears the truth is somewhere midway of the two ends. The shorted version is a bit too "etched", while the 10k setting is too soft, loosing the dynamic impact in regular SE mode. Thanks again for the suggestion.... if you have any other ideas I am glad to try them, this is not my most "familiar" territory.
Old 7th October 2013, 01:38 AM   #20
Loudthud's Avatar
It's not a constant current source because the output is tapped between R1 and R3.
Q3 regulates the voltage drop from the Drain of Q1 to the source of Q2, but when output current flows and thus changes the voltage drop across one of the resistors, Q3 tries to make a compensitory change to Q2's current to maintain the Q1 Drain to Q2 Source voltage. If Q1's current is increasing and going to the output, Q2's current will reduce. If the R1, R2 pair are the same value as the R3, R4 pair, the changes in current will be as close as the resistors dictate. Mu stage operation is preserved.
The problem is that R7 and the new resistor are too high resistance to get any bandwidth out of Q2. Try something like 470 of 1K. See the schematic I posted in the ACA thread, reply #149 Link: Amp Camp Amp - ACA
I posted that before I fully understood C2's role in modulating Q2's current.
Amp Camp Amp ModHide this!Advertise here!
Amp Camp Amp - ACA flg Pass Labs 3540 Today 06:35 PM
Amp Camp Kit Jason The diyAudio Store 40 3rd April 2017 08:18 PM
Amp Camp Amp #1 A Pictorial Build Guide N Brock The diyAudio Store 1 28th September 2013 09:23 AM
WTB: Amp Camp Amp PCBs Nisbeth Swap Meet 2 25th December 2012 06:39 PM
Amp Camp! Jason Site Announcements 2 30th June 2012 03:57 PM
Copyright ©1999-2017 diyAudio
