Strange problem with Pearl 2 and SAE Cartridge
Old 18th March 2013, 10:11 PM   #1
McQuaide is offline McQuaide  United States
Default Strange problem with Pearl 2 and SAE Cartridge
I've had this problem on and off with a NOS SAE1000e for a while now. The cartridge produces incredibly loud white noise when on the tonearm rest, but only with the Pearl 2. It's quiet with other phono stages. When the stylus hits the groove the noise quiets down.
It also makes strange sounds and loud snaps when the TT muting kicks in and out. Pulling one RCA cable kills the noise, and touching one of the signal terminals quiets it.
It only happens with the combo of the Pearl 2 and this HOMC cart. The cart is fine on other phono stages, and other carts are fine on the Pearl 2.
Any ideas Wayne?
Mark
Old 19th March 2013, 01:21 AM   #2
Russellc is offline Russellc  United States
Well Bugger. My current fav is the SAE 1000 Lt....
Russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Old 19th March 2013, 10:51 PM   #3
Bump...
Old 22nd March 2013, 03:58 PM   #4
Here's an update on my troubleshooting -- The noise seems to be related to C22. I have these caps in sockets now, so I can vary the load on the cartridges.
When I pull C22 from the right channel but leave it in the left, the noise goes away from both channels. If I pull C22 from the left channel, the noise stays in both channels, regardless of whether C22 is in the right channel or not.
This noise existed on and off before I installed the sockets, and with different caps.
Any ideas?
Old 22nd March 2013, 08:51 PM   #5
Wellerman is offline Wellerman
So if you pull c22 from the right channel, the noise goes away in both channels, and if you then also pull C22 from the left channel, the noise returns in both channels? ( I might have misread)
I would try soldering C22 in both channels to see if that works. Or alternatively, try without C22 in both channels (cable capacitance ot the TT interlink mightbe enough). I have silver mica ones in my Pearl.
Old 22nd March 2013, 11:09 PM   #6
bnorrish is offline bnorrish  United States
bnorrish's Avatar
I left off C22 in mine as a few suggested most cartridges do not need. I would leave them both off.
Old 23rd March 2013, 08:33 PM   #7
Default Solved
Well, it was something simple. This cartridge wants the TT ground to be earthed. Without that, you get blasting white noise, or crackling, or wierd tones slowly rising and falling, or radio stations, or sometimes nothing. As soon as I connected the Pearl ground post to earth it went dead silent.
My ground scheme was identical to 6L6s.
I'm now enjoying my best cartridge through the Pearl 2-Mezmerize-F5, and it sounds like I died and went to heaven
Old 23rd March 2013, 10:18 PM   #8
The saga continues...
After listening for a while, the left channel slowly fades and the some of the noises come back. None of the extreme noise from before I grounded it, but some squealing sounds.
Unplugging and re-seating the RCAs from the turntable returns everything to normal.
Does this sound like a grounding problem? It seems to deteriorate over time.
Old 24th March 2013, 07:33 PM   #9
The noise is back with a vengeance today no matter what's grounded or not grounded. I measured it and it's up to 3.7 VAC coming out of one channel and .5VAC from the other of pure static.
I took voltage readings and here they are:
R33: -24 -24
R4: 23.5 23.5
Across R6: 1.6 1.8
R6-Q4: 19.8 19.8
R9-R7: 19.5 19.5
R8-R10: 9.6 9.5
Q3-Q7: 8.9 8.9
R11-Q3: 14.4 14.5
R24-Q9: .27 .26
Q10-R28: 22.9 22.8
R28-C24: -24 -24
R25-R27: -22.2 -22.2
R29-Q11: -22.9 -22.9
R6-Q4: 19.8 19.8
Touching the bare signal connections inside the unit kills the noise temporarily.
Old 24th March 2013, 08:22 PM   #10
bnorrish's Avatar
Possibly a component on the ground plane is not properly soldered, especially one of the caps? Also check the input and output hookup soldering on the board. I had noise on one channel. I found I had a couple bad solder joints on a few caps on the ground plane, plus the input ground solder point on board was bad.
Strange problem with Pearl 2 and SAE CartridgeHide this!Advertise here!
SAE 1000 cartridge audiostar Analogue Source 1 11th November 2011 12:13 AM
Pearl Phono strange working Basill Pass Labs 3 7th August 2010 09:50 AM
Pearl Phono stage cartridge matching Gregorio Pass Labs 3 30th June 2004 10:10 AM
Pearl and Cartridge Compatibility (Goldring 1012GX) krikor111 Pass Labs 5 14th September 2003 03:19 PM
Pearl Phono- What cartridge SteveG Pass Labs 16 7th March 2002 12:02 PM
Copyright ©1999-2017 diyAudio
