Strange problem with Pearl 2 and SAE Cartridge
Old 21st May 2013, 03:32 PM   #21
McQuaide is offline McQuaide  United States
Originally Posted by vinylkid58 View Post
I sketch might be helpful. I have a 1000E that whistles a little when I first power up my Pearl I.
jeff
Let us know if it helps.
Old 22nd May 2013, 04:21 AM   #22
Russellc is offline Russellc  United States
Is "RL" in the sketch R19 on the Pearl 2 schematic? Didnt make sense that a zobel was strung "across the inputs" but appears that each input has a zobel going from input to same place R19 grounds? Or am I missing it?
Russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Old 22nd May 2013, 04:57 AM   #23
6L6 is offline 6L6  United States
6L6's Avatar
Yes.
...a zobel was strung "across the inputs" but appears that each input has a zobel going from input to same place R19 grounds?
Yes
The issue is that the SAE is a very high inductance cartridge. The Zoble loads it down so it doesn't ring.
I had the cartridge on my Pearl 2 and it did exactly as McQuaide described without the Zobel, but the fix was easy (suggested by Wayne, of course...) and the problem is gone.
The Cart sounds really fantastic, BTW.
Old 22nd May 2013, 05:02 AM   #24
Originally Posted by 6L6 View Post
Yes.
Yes
Thanks! I will install before fire up. Are 1/4 watt resistors plenty for this location?
Russellc
Old 22nd May 2013, 12:00 PM   #25
6L6's Avatar
Any resistor would be fine -- the only power it's seeing is what the cartridge can generate.
Old 22nd May 2013, 11:45 PM   #26
Thanks for dumming it down for me, much appreciated and saved me freaking out when it wouldnt play right!
Russellc
Strange problem with Pearl 2 and SAE CartridgeHide this!Advertise here!
SAE 1000 cartridge audiostar Analogue Source 1 11th November 2011 12:13 AM
Pearl Phono strange working Basill Pass Labs 3 7th August 2010 09:50 AM
Pearl Phono stage cartridge matching Gregorio Pass Labs 3 30th June 2004 10:10 AM
Pearl and Cartridge Compatibility (Goldring 1012GX) krikor111 Pass Labs 5 14th September 2003 03:19 PM
Pearl Phono- What cartridge SteveG Pass Labs 16 7th March 2002 12:02 PM
Copyright ©1999-2017 diyAudio
