I am a rookie.
But somehow I managed to build an A-75 about 2 years ago and since then I have lived with a buzzing sound, not too annoying with my main speakers but really obnoxious with some single driver boxes I am now toying with. Question: The buzz is not the traditional hum, but more like what I would suspect is related to either the diodes or voltage doubler circuit in the regulated power supply. Where should I look for the source and/or how can I eliminate (or reduce) the buzz? Thanks,
DV |
#2 |
The one and only
Look on the rails for the front end using a scope,
and if they look like they don't have any ripple, say only a few millivolts AC, then the amplifier might be oscillating, in which case you look for high frequency noise at the output, again using an oscilloscope. |
#3 |
Dave:
Did you add the bypass electrolytics to the driver card board? There was some slight oscillations that showed up on a few of these that were eliminated by placing an electrolytic from the + , - power inputs to ground on the driver cards. I think 150 mf, polarized. Keep - pointing to - and + pointing to + . This will mean where they come together at the ground you'll have a - to a + . |
#4 |
Thanks for your help. I will look into it as soon as I can stand to stop enjoying it for a while...
DV
DV |
| 4 ch esp p3a psu Buzz | kjb | Solid State | 7 | 4th August 2008 12:53 PM |
| Please help me in getting rid of the buzz. | rdk845 | Tubes / Valves | 62 | 24th May 2008 06:12 PM |
| Buzz in new amp... | chrish | Tubes / Valves | 10 | 20th February 2008 05:06 AM |
| Melos triode and computer as source: BUZZ BUZZ BUZZ | zigo3 | Tubes / Valves | 4 | 28th November 2007 03:11 AM |
| hum/buzz with pot all the way up | woodturner-fran | Tubes / Valves | 19 | 24th September 2007 01:31 PM |
| Page generated in 0.08115 seconds (73.35% PHP - 26.65% MySQL) with 10 queries |
