Pass Pearl 2 / recommended power supplies - diyAudio
Old 18th March 2013, 02:15 PM   #1
Default Pass Pearl 2 / recommended power supplies
Hi there,
Im just planning to build a Pass Pearl 2 and am wondering which power supply to use. Is the AMB Sigma 11 a good solution or can I get the same results by using a simpler one.
Many thanks and best,
Rents
Old 18th March 2013, 02:56 PM   #2
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
if you're going in to trouble of building dedicated PSU , then go to shunt reg route
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th March 2013, 09:47 AM   #3
thanks zen, which one would you recommend the sima11 single rail or the sigma22 dual rail psu?
Old 20th March 2013, 10:26 AM   #4
Zen Mod's Avatar
links ?
Old 20th March 2013, 10:43 AM   #5
bnorrish's Avatar
It is pretty easy to do the PSU as Wayne shows in his PDF on the passdiy.com website using point to point wiring. I had a spare diode board from the diyaudio.com store Universal PSU board. The rest was wire, solder, terminal blocks, wire nuts, hot glue to secure the big caps.
Old 20th March 2013, 10:48 AM   #6
bnorrish's Avatar
A little bit of a hack job but it works.
Old 20th March 2013, 10:53 AM   #7
bnorrish's Avatar
Also there is minor error in the PSU diagram. See attached from 6L6. Missing ground between bridges.
Old 20th March 2013, 10:55 AM   #8
Zen Mod's Avatar
Originally Posted by Zen Mod View Post
links ?
just realized that you're asking again about Sigma
they're series regs
that isn't what I recommended
if going that way - just make original Pearl PSU
Old 21st March 2013, 05:00 AM   #9
PKI is offline PKI  United States
PKI's Avatar
ZM, what about Salas SSHV2, or it will not work here?
Old 21st March 2013, 08:00 AM   #10
omishra is offline omishra  India
I am building simple unregulated CRC filter for on-board 7824/7924 series regulators of Pearl-2 board. Using MUR8xx diodes with 22-0-22 r-core transformer.
This is very basic and generic power supply. Component values could be experimented for different caps and resistances.
Nelson Pass Zen 4 Kit w/Power Supplies & Heat Sinks + Freebies! Compulsive Swap Meet 9 27th December 2012 03:16 AM
Pass Pearl PCBs jbanneck Swap Meet 3 16th September 2011 11:05 PM
Recommended first Pass Labs clone build commandercam Pass Labs 4 27th January 2010 04:29 PM
Pass Pearl PCB help! Are these boards OK? argyris Pass Labs 3 4th September 2008 06:41 PM
addcart.submit - 1 Pass Pearl lineup Pass Labs 4 23rd February 2006 09:14 PM
Copyright 1999-2017 diyAudio
