Old 25th November 2003, 07:05 AM   #1
lawka is offline lawka  Hong Kong
Default Careless Order
Due to my careless ordering, I purchased 100 nos of IRF9610L in lieu of IRF9610 for my Aleph Pre & Power construction. Could it still be used under same condition. Please advise.
Next, how to get the thermistor CL60. Thanks a lot
Old 25th November 2003, 05:04 PM   #2
Send a message via MSN to Tazzy
Did you compare the IRF9610L with the IRF9610 on www.irf.com?
Couldn't find L? instead I found STRL with is a D2Pak package.
Looks like smd stuff to me?
Old 25th November 2003, 05:35 PM   #3
Kermit is offline Kermit  Norway
Kermit's Avatar
Looks like irf9610L is to-262 and irf9610 is to-220.
http://dkc3.digikey.com/pdf/T033/0545-0553.pdf
Pins are identical so I think it is safe to say they can be used. The only ting i can think of is that the tab is sligtly smaler so they might become hotter..? And more troublesome to mount on a heatsink.
Sven Sødem
Old 25th November 2003, 06:29 PM   #4
The one and only
Nelson Pass's Avatar
Go ahead and use them.
Old 2nd December 2003, 02:53 AM   #5
Default Components has come
The ordered IRFP240 & IRF9610L has come to my home yesterday. Matching have to start and I checked the same characteristic between IRF9610L & IRF9610 expect their package.
I wish to ask the necessity to apply the heat sink on Q1 & Q2 of Aleph 5 because I have a look to some Taiwan DIY's product via web.
Any comments of followings for Aleph 5 :
1. 500VA transformer for single channel is enough or not
2. 18000UF 50V Malloy capacitor x 6 nr of single channel
3. Heatsink area is quite small, just 450 mm L x 150 mm H x 45 mm thick for single channel
4. CLC filter must be better while compare to Capacitor only
5. Using the brass plate for filter capacitor connection have the sound advantage really or just gimmick
Old 2nd December 2003, 04:39 AM   #6
The one and only
Default Re: Components has come
Yes
Sure.
Buy a fan
You bet
Use gold
Old 2nd December 2003, 06:44 AM   #7
Default Fans really
Mr Pass
Fans or Friends really. the noise it generated will lower my intention to listern the music.
I may propose to buy a larger chassis to provide a larger area.
Appreciate your suggestion.
Old 2nd December 2003, 07:57 PM   #8
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
yes, heatsinks never seem to be big enough!
when you think you have enough, add a little more
other than added complexity (a 12 volt power supply) a fan
wouldn't really bother me, because you can use one that
wouldn't be heard at the listening position - that could help in
cooling a lot... but most purests run screaming at the thought
i wish i could turn off my refreigerator's compressor when listening
to music... when that thing shuts off all of the sudden - your
realize how much noise pollution it's adding to the room!
Old 2nd December 2003, 08:07 PM   #9
HDTVman is offline HDTVman  United States
You should hear my furnance. It drounds out the kids. a 6 year old, a 3 year old and a 2 year old. Now that's noise pollution.
Later BZ
What ever makes the tunes flow
Old 2nd December 2003, 08:11 PM   #10
no kidding on the fridge noise - i have an open plan living room/dining room/kitchen space, and i can hear EVERYTHING. not to mention the fridge is older than any rational person should use, so it sound like a motorcyle when it comes on. (slight exaggeration.)
when i want to listen (or watch movies) in peace, i just unplug the fridge. it won't hurt anything for just a couple hours.
the other noise problem is my furnace - it sounds like a jet when the flames are ignited, and then the forced air sounds like a wind tunnel.
sorry for the OT...
/andrew - enjoying the 'sounds of silence' (ha!)
1st order Passive Line Level Crossover + 2nd order Highpass? alexclaber Multi-Way 11 4th January 2008 07:15 PM
deceptive perception ? 1st order-2nd order question poldus Multi-Way 4 10th April 2007 11:58 PM
My 1st order butterworth filter better than 4th order L-R: Why? philipreji Solid State 61 1st March 2007 04:50 PM
2nd Order Tweeter + 3rd Order Woofer = OK? Jay Multi-Way 3 12th September 2005 12:12 PM
1st Order Tweeter, 3rd Order Woofer? Jay Multi-Way 8 8th May 2004 09:29 PM
Page generated in 0.11680 seconds (72.68% PHP - 27.32% MySQL) with 10 queries
