Hello,
Here is the version of Aleph-XM amplifier, but in 'mini' version. It is also an X, two-stage balanced single-ended amplifier, with the DC feedback Zen on each output stage. The total bias is slightly below 5 A, and the total heat dissipation is around 175 W or 44 W ! per device, so the heatsinks should be rated at 0,2 K/W as the real minimum. Power output should be about 65 W / 8 Ohm, or around 45 W into 4 Ohm load, with the specified parts and the power supply. Best regards, Kristijan Kljucaric http://web.vip.hr/pcb-design.vip
#2 |
I like it. perhaps IRFP260's would be able to handle 44 watts easier. Lots of people want PCB's When do you estimate yours to be ready?
#3 |
Warp Engineer
On Holiday
A couple of IRFP044's would probably be absolutely perfect for this.
- Dan |
#4 |
What about a couple of IRFP054's?
Vision is the Art of seeing things invisable. |
#5 |
Any chance that mini - mini Aleph X may be available someday? A single transistor version with current source would be perfect for my needs.
George |
#6 | |
Looking into the circuit, it appears to me that four is the minimum number of transistors. Chnging the 0.27 ohm resistors to something like 0.54 should get the power consumption down to manageable levels for me. Are boards going to be available for this? |
#7 |
Am I being dense if I don't understand why this is "mini"? It seems to be capable of 80W into an 8Ω load, or 50W into 4Ω. My Aleph-X delivers 40W into 8 or 4Ω, and I don't consider it miniature! It's quite an effort!
#8 |
Hi Kristijan,
I’ve tried to simulate your schematic in CircuitMaker. But I don’t get the same result as you do. In 8 ohm I get around 20 W and in 4 ohm I get around 40 W. Where am I wrong? Shouldn’t I get it otherwise, more W in 8 ohm then in 4 ohm load. By the way, I’ve changed the BC550C to ZXT450, I don’t think that would cause any problem, do you? BR /loovet |
#9 |
Look dude, I wasn't gonna say anything but ...this is no different from the Grey version so it ain't no mini, it's more like another kulata from kularjic.
Wanna build it? Buy a couple of boards from Chad and get to work. |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 03:58 AM |
| ALEPH-X - The Monster | kristijan-k | Pass Labs | 26 | 24th November 2003 07:33 AM |
| Page generated in 0.10078 seconds (73.52% PHP - 26.48% MySQL) with 11 queries |
