Jim's Audio F5 power supply board - Page 4 - diyAudio
Old 24th March 2013, 11:39 AM   #31
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I wouldn't mind doing it like this myself
Old 24th March 2013, 01:39 PM   #32
I am not inclined to agree.
I think the charging pulses into the first pair of smoothing caps must be resolved at the the first pair of zero volt connections.
The smaller value but longer charging pulses in the second pair should be resolved at the second pair zero volt connections.
The hopefully very small and almost continuous charging pulses of the third pair should be resolved at the third pair zero volt connections.
This cleanest zero volt connection is then taken to the Main Audio Ground.
But back to the input to that smoothing bank.
The two AC and the Centre tap must arrive as a close coupled triplet. This triplet should be very short in length and very low in loop area. i.e. the transformer secondary + rectifier + 1st pair smoothing MUST be VERY compact.
Then arrange the cabling to minimise loop area all the way from mains input right through to speaker output terminals.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 25th March 2013, 02:04 AM   #33
Hikari1 is offline Hikari1  United States
Andrew,
I believe this is what you are talking about.
Seems like Zen is trying to minimize potential grounding issues, you are trying to minimize potential RFI issues. Both would probably work...I have not decided what to do yet. But resistors will arrive this week so I have couple days to figure it out.
Old 25th March 2013, 09:20 AM   #34
you have shown double connections from Zero volts1 (at the bottom) to Zero volts2 and again double connections from Zero volts2 to Zero volts3.
You need to add a centre tap connection to the bottom zero volts1.
You need to add a zero volts connection to each amplifier channel. This connection must go to the MAG. The MAG must be located to minimise hum.
Although your diagram is "opened up" to make it readable, I recommend that all the "open" loops be closed down such that every flow and return pair are close coupled.
regards Andrew T.
Old 4th December 2013, 10:35 PM   #35
Default Resistors ?
Wrong post.....
Old 4th December 2013, 10:41 PM   #36
Sorry for asking but what kind of resistor do you using on that board ?
I have the same but its no resistors mounted and i dont know what to use.
Stolen Trademark Amplifier from Jim's Audio on EBAY crazycloud Solid State 561 18th December 2016 01:42 AM
Jim's Audio Goldmund Telos 390 clone Tyimo Solid State 12 8th March 2015 12:41 PM
Jim's Audio F5 referenced kit. HiVi Guy Pass Labs 21 22nd November 2012 10:24 AM
Universal power supply board for audio amplifier siliconray Siliconray Online Electronics Store 11 13th February 2012 05:24 AM
Copyright 1999-2017 diyAudio
