Jim's Audio F5 power supply board
Old 11th March 2013, 09:56 PM   #11
6L6 is online now 6L6  United States
6L6's Avatar
The chipamp.com PSU board is very nice. I have used it before and happily will do so again.
Old 11th March 2013, 11:00 PM   #12
Hikari1 is offline Hikari1  United States
Chip amp board looks good. Thanks for the pic. But I'd have to order new new caps (higher UF) due to the 6 vs. 8 caps. I assume the diode section of the board snaps off?
Old 11th March 2013, 11:28 PM   #13
6L6's Avatar
Diode section doesn't snap off. You can use external bridges if you like, or the on-board, discrete single bridge.
10mm lead spacing 35mm diamater caps fit well. Lots to choose from.
Use your current caps on your next project!
Old 12th March 2013, 01:49 AM   #14
bk856er is offline bk856er  United States
bk856er's Avatar
Have you looked at the tea-bag ps board?
BK
Old 12th March 2013, 02:54 AM   #15
omishra is offline omishra  India
Originally Posted by Hikari1 View Post
Jim's audio also has this board. Anyone care to comment?
Heavy Duty Power Supply Partial Kit Pass Amplifiers | eBay
Onboard rectifiers. I am not really an expert on rectifiers...are these worse than the block type rectifiers? I would replace the resistors. Also, would a f5 build require two of these boards? I only see one set of secondary in/out.
Audiosan: I looked at chipamp.com but could only find images of a PS board that uses 2 caps....
I don't know your purpose. But I built descrete rectifier board and each of the dual diode gets fairly warmer with small heatsink. Now I feel diode block without heatsink will get hotter.
Btw I have these boards purchased for some purpose. I did not use it, it looks fairly good quality though.
Old 23rd March 2013, 07:24 AM   #16
Well, I decided to point-to-point the power supply. Wish me luck. Still waiting on resistors and bypass caps in the mail...
Old 23rd March 2013, 07:53 AM   #17
AudioSan is offline AudioSan  Norway
6x nippon chemi-con 33.000uF 50V caps from apexJr?
Old 23rd March 2013, 10:24 AM   #18
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 23rd March 2013, 05:06 PM   #19
Yes, 6x33000uf from Apex jr.
So, what is the best place for the resistors/bypass caps? After the first set of caps or after the 2nd?
Zen, your proposing a single ground location instead of my ground 'bus'. Actually I wanted to use a copper plate but couldn't find a suitable plate. Do you think the grounding design I am using will be a problem?
Old 23rd March 2013, 06:16 PM   #20
Zen Mod's Avatar
it will be problem, most probably
copper plate is OK , but even then you must think where you are going to put wires
Jim's Audio F5 power supply boardHide this!Advertise here!
Jim's Audio Goldmund Telos 390 clone Tyimo Solid State 18 7th January 2018 08:46 PM
Stolen Trademark Amplifier from Jim's Audio on EBAY crazycloud Solid State 562 14th October 2017 02:29 PM
Jim's Audio F5 referenced kit. HiVi Guy Pass Labs 21 22nd November 2012 10:24 AM
Universal power supply board for audio amplifier siliconray Siliconray Online Electronics Store 11 13th February 2012 05:24 AM
