F5 increased capacitance
Old 7th March 2013, 10:29 AM   #21
JOHNNYCR100 is offline JOHNNYCR100  Abu Dhabi
Hi Boys, may I ask a newbie question?
When in china I can get a 300V/A 220 v primary /2 x 18 volt output secondary transformer, however my mains input where I live is 240v, so to get 2 x 18 volts output on the transformer, what input voltage input should I select? (Bearing in mind my input is 240v not 220 v) should I select a lower secondary to get 18 v out or vica versa? (or wont it matter?)
I am interested to ask since I was looking at some mondorf mlytic caps from hi fi collective (2 x 47,000 uF per channel) at a nice price (around 12 UKP each) but there only rated at 25volts DC (+20% extra on the spec) my PSU PCB only has room for 2 caps per channel hence the fetish for the 47,000 Uf caps--or -are there better cap recommendations ???
see link: http://www.hificollective.co.uk/components/mcap_mlytic_si.html
Am i sailing to close to the wind here, or is the on load voltage low enough to be safe within the cap max tollrence
Thanks boys--blowed if i know!
regards
Johnny
Old 7th March 2013, 11:07 AM   #22
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
I wouldn't risk using a 220V transformer at 240V, it might well overheat.
But to answer your question all you need to do is find the Np ; Ns ratio.
220 / 18 = 12.2
So at 240V you should get 240 / 12.2 = 19.7V.
To get 18V you would need to find a 18 x 220/240 = 16.5V transformer.
Old 8th March 2013, 04:37 PM   #23
Thanks Katieanddad, looks like i wont be getting a cheeop Chineest Tx, ill save and get the Amtek (or piltron if rich?)
Thank you for the easy to understand explenation sir
Any one idears on the Cap issused raised here?
cheers
Johny
Old 8th March 2013, 04:43 PM   #24
AudioSan is offline AudioSan  Norway
go for 35V caps. and use the 220V transformers. that is no problem.
and i would get another PSU Board, that can hold minimum 4 caps and can be used With CRC/CLC filter, bleader resistor and bypass caps.
Old 10th March 2013, 07:43 AM   #25
Thanks Audiosan, I have the Paul Danuals PSU board with only 2 cap per PCB, wish i had the option of say 4 x 22,000 uf- that would be easyer- Mundorf look good but i think others have used Panasonics to good effect?
cheers
Johnny
Old 10th March 2013, 08:26 AM   #26
do you mean peter daniels?
those Boards are single rail. so you ned 2 of them. 1 for +rail and 1 for -rail. so then you have for 4 caps, bleader resistor, CRC/CLC and bypass caps. if you want seperate PSU for each ch, then you need 4 PSU Boards.
Old 11th March 2013, 03:40 AM   #27
Hi Again Audiosan,
Thanks for the reply to my inept questions, yes I read the circuit diagram again, now i understand!, think i got confused!! but as i am building monoblocks i do indeed require another set of PCBS.
But at least i can get a set of 4 (per channel) of 22,000 UF caps in with decent voltage ratings (35v) - it may be a good idea to reconsider and get 2 x DIY universal PCBS? for a monoblock configuration?
Any how thanks Audiosan-i now "get it"- keep em coming .
Best regards
Johnny
(PS- Paul Daniels was a Magician who worked for the BBC IN THE 1980S-- what was i thinking??)
F5 increased capacitanceHide this!Advertise here!
High efficiency = Increased dynamics ?! soundaatma Full Range 32 8th November 2012 01:14 AM
Can the BL of a driver be increased? GestaltH Multi-Way 11 20th March 2008 12:53 PM
increased choke inductance - recommended? cbutterworth Tubes / Valves 8 16th October 2007 05:18 PM
Increased symmetry in amplifier Danyele82 Solid State 2 7th December 2004 09:29 PM
Increased gain for IGC Nuuk Chip Amps 9 28th May 2003 11:13 PM
