to all in the Pass DIY Nation
Old 27th February 2013, 06:22 PM   #1
daly2k is offline daly2k  United States
Default to all in the Pass DIY Nation
Well I don't know if I have to apologize or not but I fell off the DIY wagon and bought a used pair of XA100.5 power amps. Yes I know that I built a pair of x amps from this thread which were actually a converted pair of Aleph 200's I had built in 2001. I also have built the Pass/Thoroguard A75 which I am retiring after 23 years of faith full service-it is starting to hum and I suspect the poor caps.
The question I have is that I have bi amped line arrays. I also bought about 6 years ago a Pass X350.5. The idea is to have an all class A driven loudspeaker.
I am now beset with do I use the 350.5 to drive the tweeters as for sure it will never leave class A or use it on the mid/woofs where it just might happen? Crossover is at 2700hz.
By the way my wife was never impressed with my metal work or that the enclosures were mounted on dolly wheels.
When I wanted to rebuild the X amps using a stripped engine small block V8; put the tranny in the oil pan and the outputs in the heads with the input board on the manifold she was ready to call the doctor. Of course I would use the politically correct chrome covers.
Old 27th February 2013, 06:47 PM   #2
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
not really enough info
wee need you to cover other possibilities , same as more info about spks and amps - are you using just these two amps , is there subwoofer (needing an amp or two ) etc .
off course it looks as blasphemy using so potent amp just for tweets , when you can have smaller - more economical one , and in same time most probably sweeter sounding
.......... Of course I would use the politically correct chrome covers.
in that case , most possible is that Doc would be on your side ; all men are weak on chromed covers
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 27th February 2013, 06:58 PM   #3
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
to all in the Pass DIY Nation Send a message via Yahoo to vdi_nenna
Just my 2 cents, but try both ways. I would use the XA100.5 on top and the X350.5 on the bottom.
He's right. But, you have to do with what you have, right?
I use a 5w for 120Hz to 20k.
I build, therefore I am.
Old 27th February 2013, 08:07 PM   #4
Default to all Diy
[ATTACH]333028
Zen Mod
I have line arrays, each speaker has 12-5inch ribbon tweeters and 12-5inch eton cone mid/bass with a ported output. Useful output is down at about 45hz.
These speakers are crossed over to subs at about 60hz. The subs have built in 300 watt class AB plate amps and their own cross over controls plus volume.
The line arrays are biamped at 2700hz @ a slope of 48db/oct.
My issue with my home built X projects is the relative DC offset varies especially while the amps are heating up so I don't use them for the tweeters.
I use them on another hard working system.
I listen to music from 75-85 db so I think I have more than enough power. I also built a passive outboard xover for the line arrays at 24db/octave and 2500 hz.
To protect the tweeters I can put about 50 uf of cap. in series with the +/- signal outputs of the tweeter amp but I don't like doing this. I love the class A Pass sound and my wife can live with the design of the factory amps.
I enjoy working on electronics during the winter months but prefer being outside during the summer. The factory amps have very low relative off set at less than 5mv. My tweeters do have an impedance matching xformer and in theory should be immune to dc but I am trying to be safe. thanks for the feedback. dave
Old 27th February 2013, 08:19 PM   #5
siouxiebuff is offline siouxiebuff  Sweden
Send a message via MSN to siouxiebuff
Hm, U definitely have to apologize!
Kiddin; U cant focus on class A, B or whatever in that way. There are AB-amps that are totally usable in your setup. U could build a good AB-amp and compare to a bad A-amp untsoweiter. There are several ways to move distortion out of an amps window of operation.
Old 27th February 2013, 08:27 PM   #6
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
that turntable is absolute junk, you better send it over to the east coast and I will 'recycle' it for you!
Salas Boards GB 2017#1 SHIPPED | GB 2017 #2 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards In Stock
Old 27th February 2013, 08:45 PM   #7
Zen Mod's Avatar
if you like both amps , especially 'cause you owe them already , then just try which one you prefer on top , and keep like that
sweet dilemma
Old 28th February 2013, 02:35 AM   #8
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Put the 350.5 on the bottom.
Old 28th February 2013, 10:39 AM   #9
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
the Pass/....... A75
Mr Norman Thagard (turning 70 this year)
Nothing wrong with Edelbrock/block, "edel" means noble.
(how much for the antique Rorschach gun in the window ?)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 28th February 2013, 11:09 AM   #10
Jay is offline Jay  Indonesia
Banned
Of course, if your ears have no idea which one is good at which, then use the politically correct decision, which is what NP sayz...
to all in the Pass DIY NationHide this!Advertise here!
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Help me get a taste of Pass diy dake13 Pass Labs 33 3rd November 2007 01:29 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
Why the Pass DIY Add? lgreen Pass Labs 4 25th October 2003 12:43 AM
Copyright ©1999-2017 diyAudio
