Old 21st November 2003, 04:54 PM   #1
MaXiZ is offline MaXiZ  Italy
MaXiZ's Avatar
Send a message via ICQ to MaXiZ
Default Active crossover
Hi to all.
Did someone tryed this?
I know it's from ESP.
I've just build it but no sound from it..
Maybe i'm doing something wrong as always..
How shoud i connect the speaker?
I mean the gnd should be connected to gnd of car stereo or the gnd from the output of car stereo were i connect the speaker??
And what's the right way to test it?
How i can check if the crossover is running correctly?
And is there a way to check if the Opamp are ok?
Old 21st November 2003, 05:05 PM   #2
HDTVman is offline HDTVman  United States
Default Re: Active crossover
Originally posted by MaXiZ
Hi to all.
MaXiZ this is a low level crossover. By reading your post is seems like you are tring to connect the speakers to the output of the crossover. You need to use an amplifer for each output of the crossover to drive the speakers. The input to the crossover would be low level also (RCA jack) not the speaker output of the stereo.
Good Luck BZ
What ever makes the tunes flow
Old 21st November 2003, 05:21 PM   #3
MaXiZ's Avatar
What mean?
I'm a beginner...
Exactly... The positive to the output of crossover and the negative at the negative of car stereo output...
Wrong right?
And a preamp right???
What's the difference excuse me???
The input at the crossover should be the positive of car stereo speaker connection output right???
And is there a way to check if the xover is running correctly? Is a good idead to connect a +12V at the input for example? Just to see if there's a certain voltage output...?
Old 21st November 2003, 05:55 PM   #4
Vigier is offline Vigier  Netherlands
About the last part: DON'T connect the 12V at the input. The 1µF will probably block it, but if not, you can throw away your OpAmps, and I don't think you want that!
Grtz, Joris
Old 21st November 2003, 06:09 PM   #5
MaXiZ's Avatar
ok and could u explain me the other quesion? and ho to check if an opamp is ok?
Old 22nd November 2003, 11:45 AM   #6
What mean?
I'm a beginner...
This means that the audio signal is at a low level, used to go from one audio component to another. Very little power at this point.
Wrong right?
Wrong!
The "positive" output of the high to the input of the tweeter amplifer, The "positive" output of the mid to the midrange amplifer and The "positive" output of the low to the input of the woofer amplifer. The negitive for each output is used for the shield connection of the cable used to take the signal to the amplifers.
No. The crossover operates at the output of a preamp, or in the case of car stereo equipment, the RCA jacks found on the better equipment intended for use with an external high power amplifer.
The amount of power present for starters. The input for this type of active low level crossover would only be .001 or .002 watts and the output power is about the same.
That would be true for a high level passive crossover, a big set of coils and caps, but that's not what you have. The crossover you have is intended to divide the tuner/ CD/ cassette output signal into 3 frequency ranges. These 3 signals then go to the input of amplifers which drive the speakers.
To test the crossover you should use a signal generator or a small battery powered CD player as the input. The signal path could then be checked with an oscilliscope or the output connected to the input of any amplifer with a speaker connected to the amplifers output.
If this is not clear to you maybe you need to find someone local to you that can show you these things.
Later BZ
Old 22nd November 2003, 02:59 PM   #7
MaXiZ's Avatar
Ok and can i explain me this...
Stereo=>Crossover=>High=>Amplifier=>Speaker (soung ok)
=>Mid=>Amplifier=>Speaker (soung baaaad)
=>Low=>Amplifier=>Speaker (soung ok)
With sound bad i mean that i ear what i should but i ear an heavy noise... And i don't mean a "gzzzzzzz" but something similar to "wiiiiiii" "beeeeeeeeeeeeeeeee".. I hope to get explain! ANyway i ear this only at the mid and not at the low/high..
I use a SMPS to supply the crossover (+/-15V)
Old 22nd November 2003, 03:54 PM   #8
I can only quess but I think that the opamp for the mid output may have failed. The noise you hear is the noise from the power supply because the opamp is shorted. But that is just a quess.
It could be an error in the wiring.
Later BZ
Old 22nd November 2003, 04:45 PM   #9
5th element's Avatar
Yeah ive used active xovers before still do now infact and am making one, need the copper clad to arrive. Anyway. In my whole time making them I have had wiring problems and have neva killed amp opamp, however I was also using all the correct inputs and outputs. Anyway the only time I killed an op is wen I accidentaly put one the wrong wasy round in its IC socket, the whole thing got v hot and just died.
I have also had very odd and not nice noises from the circuits wen not wired rite, once the problem is sorted it all worked fine. No dead opamp, so there is still hope yet.
Hope you do get it sorted,
Cheers Matt
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 22nd November 2003, 06:04 PM   #10
DRC is offline DRC  United Kingdom
DRC's Avatar
Check around the 2 opamps too the left of the MID out (no IC numbers !). From your description all others must be working. Did you build stereo ? Are both channels the same ?
Good luck, Dave
active crossover: fir vs iir netchris Everything Else 3 29th July 2008 09:14 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
PA vs DIY active crossover paulspencer Multi-Way 46 27th November 2004 01:25 AM
active crossover aaronboumans Analogue Source 4 31st May 2003 04:59 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Page generated in 0.15758 seconds (66.03% PHP - 33.97% MySQL) with 10 queries
