Building an F5 Turbo v2 (in-Progress)
Old 1st April 2013, 07:44 PM   #61
buzzforb is offline buzzforb  United States
buzzforb's Avatar
good. I just ordered some.
...Shape the sound , Man!
Old 2nd April 2013, 05:22 PM   #62
duder1982 is offline duder1982  United States
duder1982's Avatar
This thread should have some good info.
If I cant build it or fix it I really dont want it.
Old 5th April 2013, 01:43 AM   #63
6L6 is online now 6L6  United States
6L6's Avatar
Well I finally have gotten a new set of output Fets, and the time to get back into this project.
The short story is that the compensation cap from gate to output (marked as C2 on the output boards, but marked as C3 and C4 on the V3 schematic) need to be used. 1000pF is working well.
Also the gate resistors have been increased to 680ohm. These two changes have seemed to keep it stable. Hooray!
Only one channel up and going right now, the other will be done tomorrow. If everything behaves, I will hopefully have some simple power measurements.
Old 5th April 2013, 02:43 AM   #64
6L6's Avatar
A few shots of the bench -
The Front-end board is mounted on the DIY-friendly base because it fits.
Yes, it looks like an explosion at a spaghetti factory - and this is only with one channel... Now I will be the first to mention that I haven't loomed anything together yet, and that will help a bit... but the penality of having the flexibility of the seperate FE board is all the extra wires.
Old 5th April 2013, 03:39 AM   #65
bnorrish is offline bnorrish  United States
bnorrish's Avatar
Originally Posted by 6L6 View Post
The short story is that the compensation cap from gate to rail (marked as C2 on the output boards, but only on the V3 schematic) need to be used. 1000pF is working well.
Looking great! Those are labelled C3 and C4 on the V3 schematic?
Old 5th April 2013, 04:14 AM   #66
6L6's Avatar
Yes. The DIYaudio PCB has it labeled as C2 on the output boards.
Old 5th April 2013, 12:09 PM   #67
Rixsta is offline Rixsta  United Kingdom
they need to be used in V2 ? or is that only if theres a stability problem, personal id rather be safe than sorry so perhaps i should follow in your footstep(s).
www.rikibuckingham.com... DIY=Zen V4, Zen-lightenment‎, Jean Hiraga 20w,
ACA, F5, F5T, Audio Freaks Club
Old 5th April 2013, 03:28 PM   #68
PKI is offline PKI  United States
PKI's Avatar
So yes, 6L6, you say that your amp was blowing outputs because of these oscillations without this cap? I am interested, cause I am planning on dropping in two extra pairs in my F5Tv2. The question if i too need this cap or not :-)
Old 5th April 2013, 03:57 PM   #69
buzzforb's Avatar
If I get a chance, I am gonna hook up the output boards, such that I have 4 output pairs running off single FE board. This will be with standard 47R gate resistors and no cap. fun times.
Old 5th April 2013, 04:06 PM   #70
PKI's Avatar
I can do it anytime now, I just want to modify mounting technic on my 5U chassis, so I will be able do swap amps in no time. It requires some metal work and sanding, just being lazy :-)
Building an F5 Turbo v2 (in-Progress)Hide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 07:12 PM
F5 turbo heatsinks AudioSan Pass Labs 22 9th December 2015 05:12 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
Best way to tune in BIAS F5 V2 Turbo Blink_PT Pass Labs 17 4th January 2013 11:40 AM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
