Old 19th February 2013, 09:20 PM   #51
PKI is offline PKI  United States
PKI's Avatar
They are TO-220 but size is: 25.40mm x 19.05mm, the same as yours, 6L6.
Regarding thickness:
SP900 has 1.6 W/(mK) @ .23mm thickness
SP2000 has 3.5 W/(mK) @ .38mm thickness
So, Therm cond./pad: SP900 0.37 vs SP2000 1.3 in whatever units :-)
Old 24th February 2013, 01:51 AM   #52
PKI's Avatar
btw, why have you decided not to cascode?
Old 24th February 2013, 02:50 AM   #53
6L6 is offline 6L6  United States
6L6's Avatar
Two reasons -
1) For illustrative purposes I am trying to build a V2 as close to the schematic as I can.
2) If all goes well, once the V2 is done, a cascode V3 will be made in the same chassis.
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 24th February 2013, 02:57 AM   #54
PKI's Avatar
I see :-). It will be a very hot amp :-)
Old 24th February 2013, 03:38 AM   #55
oh. i've missed this tread 6L6 you will reach the chassis max before the amp's max
with +/-32V and 1.9A bias(standar V2) thats about what that chassis can handle without external cooling of some sort.
for +/-45V+ even a monoblock will have broblems when you bias it up to "full" power.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC).
Vivaldi8 speakers
Old 1st March 2013, 11:14 PM   #56
6L6,
Any update on your build? Are you able to keep MOSFETs from shorting out?
Thanks,
Steve
Old 2nd March 2013, 12:15 AM   #57
6L6's Avatar
I've only just received (in todays mail) some different parts to try again. There is a place for a compensation cap on the output boards, and I needed to get some of those to try. I am also going to a much bigger value gatestopper.
Pass F4
Old 1st April 2013, 11:51 AM   #58
Rixsta is offline Rixsta  United Kingdom
Send a message via Skype™ to Rixsta
Hi, nice build
Is there any reason to use the Thermal pads over Mica & grease ?
ive had best results with the mica
www.Rixsta.co.uk Free music recorded by me/DIY pics+ebay-shop, amps=Zen V4, Zen-lightenment‎, Jean Hiraga 20w, F5
Old 1st April 2013, 12:42 PM   #59
There is one brand of Thermally conductive pad that significantly outperforms 1thou mica.
So far I have not seen any Members posting details of any competitor product that can match Keratherm's Kerafol 86/83.
If the others don't catch up quickly, they can only go broke.
Old 1st April 2013, 05:21 PM   #60
PKI's Avatar
Some experience about thermal pads:
we discussed earlier these two:
To not be speculative I bought two of them and tried. SP2000 are much better pads. I do not trust my thermocouple from DMM in terms of super accuracy, but with SP2000 TO-247 case of F5 is about 5C cooler.
F5 Turbo is posted Nelson Pass Pass Labs 589 1st March 2013 01:19 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
Best way to tune in BIAS F5 V2 Turbo Blink_PT Pass Labs 17 4th January 2013 10:40 AM
F5 turbo heatsinks AudioSan Pass Labs 16 19th April 2012 11:54 AM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2013 diyAudio
