Old 18th February 2013, 09:22 PM   #31
buzzforb's Avatar
Save smoke later.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 18th February 2013, 09:29 PM   #32
PKI is offline PKI  United States
PKI's Avatar
The question is: can I stack transformers on a top of each other? It will help me to put them far from the boards and save me some space for nicer wiring. However, I do not want them to be coupled though the "leaking" magnetic field... and I have no idea how it is important.
I can make some estimations, but being a theorist I know how far can it be from reality ;-). Thats why I'd like to rely on engineering experience :-)
Buzz, I did the same thing on my aleph's trims half a year ago, I used a different color, but patent is pending ;-)
Old 18th February 2013, 09:35 PM   #33
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
yes , you can
put ring of softer and thicker rubber between them
I'm using it all the time , on both sides of toroid , glued with neoprene based glue
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 18th February 2013, 11:18 PM   #34
6L6 is online now 6L6  United States
6L6's Avatar
Originally Posted by danielutzu View Post
6L6: how did you configure the first PSU board with the filter resistors so that all 8 caps are connected BEFORE the resistors (and not 2 caps before the resistors and 2 caps after them per rail)?
Sorry I didn't see this sooner...
I didn't.
On the first board there are 4 caps after the bridge, then the resistors, then the next 4. The next board is connected in series via some wire, where there are 8 caps. The resistor postions need to be jumpered on the 2nd board. Also on the second board is where the bleeder and LEDs are mounted.
There wasn't an easy and clean-looking way to evenly divide the 2 cap banks. That said, this could be considered a CRCRCRC filter, as the wire and jumpers have some resistance.
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 18th February 2013, 11:48 PM   #35
Two questions, if I may:
a. What varies if one is building monoblocks?
b. How much is different from a V3 build, up to this point?
Old 19th February 2013, 12:06 AM   #36
6L6's Avatar
a) V2 or V3 monoblocks? In either case you would only need one Front-End board.
b) The V3 would need the cascode transistors in the Front-End, and their associated parts, and the pictured output boards and power supply would be for one channel. I.E., what you see so far (and the other heatsinks, which you haven't seen yet,) would be for one monoblock channel.
The rule of thumb is that a stereo V2 or a mono V3 will be in a 5U 400mm 'Big Amp Chassis'
Pass F4
Old 19th February 2013, 03:39 PM   #37
V3 monoblocks (but since the answer is the same, I guess it does not matter?).
Darn, so I will have to buy 2 5U 'Big Amp chassis'? Time to buy some chocolates and a bunch of flowers for the spouse.
Old 19th February 2013, 03:48 PM   #38
6L6's Avatar
Lol, yes, you will need basically 2 of everything you are seeing in this guide.
The (stereo) V2 PSU will be good for one V3 monoblock, the 5U 400mm chassis will hold either a stereo v2 or mono v3 etc...
I just though of something -- I bet that with just a little creativity you could make a BA-3 front-end (which is a great preamp gainstage) on the F5T Front-end boards... The circuit isn't all that different, and there are lots of places to mount things on this particular PCB. And if you are building monoblocks, you will have a pair of FE boards extra...
Pass F4
Old 19th February 2013, 04:16 PM   #39
6L6's Avatar
THIS IS EXACTLY WHY YOU NEED A LIGHT BULB MAINS LEAD --
Look at this photo:
It looks good, yes? It's not. The wire color from the rectifier is logical - Black is V-, white is GND, and red is V+. Looking at the polarity of the caps, it seems that the leads are going to the proper place... but the board isn't setup that way, and the polarity of the caps looks backwards to how it's wired.
The PCB is marked correctly. I didn't double check the markings, and got it backwards.
I tested the amp PSU with a bench-top power supply, and this this the first time it has been powered on it's own.
The only thing that saved me from letting the smoke out was the current-limiting of the light bulb mains tester.
I have been smart and lucky enough to always turn on everything during building and testing with the light bulb mains lead first to save me from my own mistakes.
Pass F4
Old 19th February 2013, 04:41 PM   #40
I think I have seen this somewhere before on diyaudio (mains light bulb tester.), but would it be possible for you to upload a photo of where the light bulb is connected in your circuit? 100W bulb?
F5 Turbo is posted Nelson Pass Pass Labs 589 1st March 2013 01:19 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
Best way to tune in BIAS F5 V2 Turbo Blink_PT Pass Labs 17 4th January 2013 10:40 AM
F5 turbo heatsinks AudioSan Pass Labs 16 19th April 2012 11:54 AM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 16.67%)
Copyright ©1999-2013 diyAudio
