Building an F5 Turbo v2 (in-Progress) - Page 14 - diyAudio
Old 24th May 2013, 06:16 PM   #131
buzzforb's Avatar
Andrew,
I am not saying that it might not make things more stable, but was is the signfigance in performance gains if you are operating with a stable amp? Do you expect decreased distortion and if so, how much? IF degenerating them and lowering overall temp, do we avoid some of these effects. Does cascoding them further diminish the effects, as it lowers overall temp. Is there any data showing the difference between coupled and non- coupled performance. I know EUVL looked into it and made a heatsink, but don't know if he had data showing the difference.
...Shape the sound , Man!
Old 18th June 2013, 02:58 AM   #132
Rixsta is offline Rixsta  United Kingdom
Send a message via Skype™ to Rixsta
Would you be so kind 6L6 as to show us how you have your F5t wired now ? which way worked best with those diyaudio boards ? and how did u fix your ground loop!
Im having some issues still with the ground loops or Hum, whichever it is!
nothing beats seeing visually how it should be done! from the masters themselves ;-)
I have ground going to the gain stages first then from there to Pch and Nch boards.
atleast i got the bias problem sorted now
50 DEG, 0.31 bias
lovely!
www.rikibuckingham.com... DIY=Zen V4, Zen-lightenment‎, Jean Hiraga 20w,
ACA, F5, F5T, Audio Freaks Club
Old 9th December 2013, 12:55 AM   #133
Hi Jim,
I'm ordering parts to build F5T. Can you tell me which is the part number of the thermal shutoff you used? Is it really needed? And what is the height of the board stand off you use to allow installation of the mosfet?
Old 9th December 2013, 02:06 AM   #134
6L6 is offline 6L6  United States
6L6's Avatar
I honestly don't know the part# of the thermal. It was a suggestion from another member as I found it imposible to search for on Mouser. No, you don't really need it.
5mm M3 or taller standoffs should be enough. For what it's worth, because there is so little on the small PCB that holds the Mosfets and diodes, you don't really need standoffs for those boards. It certainly doesn't hurt to have them however.
Old 9th December 2013, 02:41 AM   #135
Thanks Jim, so it will be without thermal shut off and without board stand off. I like easy and affordable solutions like this.
Old 9th December 2013, 04:38 AM   #136
6L6's Avatar
You will still need something to hold the front-end board...
Old 6th January 2014, 10:02 PM   #137
Mallard is offline Mallard  Germany
Hi 6L6,
I'm sorry to ask this but I don't understand the different directions of your arrows on P1 and P2. My understanding was anticlockwise decreases resistance and clockwise inreases resistance. Why did you do P1 and P2 in a different way?
I remember my F5 both pots P1 and P2 where handled in the same way.
And it was my plan for my new F5T V.2 -> I turn both pots anticlockwise until I can hear a little "klick" and than start the biasing procedure.
Regarding P3: Can't I just count the whole turns from Zero to Max and then put it exactly in between? When I count correctly in total it's 62 turnings, so set it to 31 and I should have pretty much the mid of 200Ohm.
Again I'm sorry for asking such low skill questions but I better ask twice easy questions rather than blow up everything just because of a misunderstanding.
Originally Posted by 6L6 View Post
There are a couple of things that need to be done to the FE board when you are stuffing it -
1) Set P3 to it's middle value - with an ohmmeter measure from the wiper and one leg to the other leg and set the approximate middle. (about 100 ohm) Now turn the pot around, measure from the other leg and wiper to the first leg and set it to the middle value. You will find that as you flip the pot you will eventually find the equal setting. But as the pot track isn't exactly 200 ohms long, the null will not be exactly 100. (it will be very close, however.)
2) Turn the bias pots (P1, P2) all the way down. Measure that before soldering. Then make a mark on the pot to show which way increases the resistance.
Old 6th January 2014, 11:19 PM   #138
6L6's Avatar
The pots are mounted to match the PCB. Anticlockwise is only "down" if the PCB and pot are arranged to react that way. So "Down" will be whatever direction gives you the lowest reading across TP1-TP2 and TP3-TP4.
Yes, you can take P3 all the way to one direction and then go back halfway.
Old 7th January 2014, 09:55 AM   #139
Ok, that means on the gain stage pcb v.2.2 before starting biasing process :
P2 has to be turned anticlockwise to Zero (between TP1-TP2) and
P1 has to be turned clockwise to zero (between TP3 - TP4)
---> CORRECT?
Old 7th January 2014, 11:28 AM   #140
Mallard,
On the current store boards the pots operate in the same direction. i.e. I rotated the rightmost pot so that they both zero anticlockwise (or clockwise, can't remember and I'm away from home at the moment so I don't have access to the drawings).
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 turbo heatsinks AudioSan Pass Labs 22 9th December 2015 04:12 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
Best way to tune in BIAS F5 V2 Turbo Blink_PT Pass Labs 17 4th January 2013 10:40 AM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2017 diyAudio
