Old 26th May 2010, 03:03 AM   #191
BDP is offline BDP  United States
If you run them hot enough you could use thermocouples to generate a DC voltage.
BDP
Old 26th May 2010, 04:08 AM   #192
Fenris is offline Fenris  United States
Thermocouples are too inefficient and require too much of a thermal differential to be of any practical use.
I've seen the stacked copper idea before using copper roof flashing. Very effective but required a fan to get air between the fins and the heat required to solder the whole thing together (about 6x6") was...nontrivial. Half an hour with a torch and an insulator was required IIRC.
If you want to DIY your own heat pipe cooler:
Benchtest.Com - Heat Pipe 1
Passive Thermosyphon | Overclockers
CPU Vapor Cooling Thermosyphon | Overclockers
Listen to the music through the stereo, not the stereo through the music.
Old 26th May 2010, 07:32 AM   #193
Originally Posted by Fenris View Post
Thanks for the links, very educative. Finally, I think a more efficient solution is to buy some cheap used cpu pipe heat sink and find an elegant way to mount them on the chassis.
Old 26th May 2010, 08:37 PM   #194
...I've seen the stacked copper idea before using copper roof flashing. Very effective but required a fan to get air between the fins and the heat required to solder the whole thing together (about 6x6") was...nontrivial. Half an hour with a torch and an insulator was required IIRC...
What i liked about the Jungson version of stacked copper is there is no evidence of solder at all. Probably there is a central hole and a long bolt through all. Also, it might scale up to aluminum reasonably well. If the copper squares are 10cm per side, to double surface area only requires something between 14 and 15cm per side. Troels says the amp idles at about 170 watts and barely gets warm to the touch.
To-3 Heatsinks sandstorm33 Swap Meet 8 6th February 2008 04:33 PM
about heatsinks bigpanda Solid State 2 4th May 2005 03:34 PM
Heatsinks DD_Davo Chip Amps 2 13th April 2005 01:00 PM
Heatsinks Peter Daniel Swap Meet 19 3rd February 2004 11:08 PM
Heatsinks for DoZ ultrachrome Solid State 0 4th February 2003 09:23 PM
Page generated in 0.07849 seconds (71.63% PHP - 28.37% MySQL) with 11 queries
