#11 |
Hi Mark,
Could you please elaborate a little bit on the method of gleuing plates and fins together etc. I did not completely understand your post. (What do you mean with channels here?) It seems to me it could be an interesting method for DIY. Are good thermal conductive adhesives easy to get? What about black anodisation and glueing?
The way you do things, things do you |
#12 | |
for good heatsinks +DIY , the surplus market is where to go -- |
#13 |
My first advice is look up bonded fin heat sinks. Get some ideas of your own. To create a thick base plate is a given. The thickness of the radiating fins is more indepth. I don't pretent to be a thermal engineer but there are some great guides on the net from the many heat sink manufactuers. Common sense will tell you that thinner metal will cool off more quickly. The placement of the fins can be shown in the manufactured examples you might want to search out. Here is a bit of a scetch to get the idea across.
The grooves could be cut on even a table saw. As for their thickness it depends on the width of the fins. The other possibility is to bond thin aluminum sheet metal bent up in a suitable pattern. This option is really only economically feasable if you know where to get srcap aluminum and have at least ruimentary mechanical skills. As for the glues I don't know where in europe. Most heatsink manufactuers have a type. And the big adhesive manufactuers will also have something (loctite, hernon,etc) This is not a run out and do it type project. It will take preparation. But the gee wiz factor is there. The possibilty to dissipate heat is there. So why not??? Mark
Mark |
#14 |
This is my proposal.
Add aluminium L sheets to aluminium plate using pop rivets. Add some "heat conduct grease" between those L and plate parts. Those L parts can be different sizes if you want. Of course you can add some kind grid or grill to cover that odd looking heatsink
right way boy... u sold farm and bougth booze |
#15 | |
Computer part dealers should have silicon (pi) or silver grease if you mean that! Also somekind heat conduct glue is possible get from those PC shops too.
#16 |
I have planning this kind heatsinks because local metal dealer have that 'P' or 'half U' model aluminium bars.
#17 |
The one and only
Whatever local dealers have - that's what you go for.
#18 |
Don't want to spoil the fun but...
If I would go to my local hardwarestore (which isnt expensive, much cheaper than large diy mals) and would order an alu. plate 10 mm thick of 200*300 mm (lets say) and 10 200 mm long L profiles (30*60, 4 mm thick) I doubt it would be much cheaper than then the 300*200 Seifert heatsinks that I use now ($ 60, which btw has a 16 mm base)). Maybe if you do all the sawing and cutting yourself. And then it still has to be anodized..
Is that all there is? |
#19 |
Somebody mentioned machining of heatsinks....that one is easy to take the fun out of....aluminium bar will set you back at least 6usd per kilogram for a reasonable quality....and even if you got the aluminium for free, its "no can do" cause the material would work(bend and stretch) because of uneven material removal...it would be virtually impossible to make a flat side.
To make a heatsink of aluminium profiles (or even better copper) is the way to go if you want conventional looking heatsinks. Just use heat conductive epoxy (can be bought at RS, Farnell and so on) A different solution thats a little easier and just as good (if not better) is to cut sheets of metal and use metal blocks as spacers in between...then just bolt the whole thing together....now thats a 10 thumbs solution Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#20 |
How about buying a sheet of Aluminium and then folding it ?
Folded fins heatsinks are supposed to be very good. A thin (1-2 mm) sheet of Aluminium cant be that expensive). Folding it can't be that hard. When the folding is done glue it to a thicker copper/aluminium sheet. What do you think ? I'm really thinking of trying this... /Tobias |
| To-3 Heatsinks | sandstorm33 | Swap Meet | 8 | 6th February 2008 04:33 PM |
| about heatsinks | bigpanda | Solid State | 2 | 4th May 2005 03:34 PM |
| Heatsinks | DD_Davo | Chip Amps | 2 | 13th April 2005 01:00 PM |
| Heatsinks | Peter Daniel | Swap Meet | 19 | 3rd February 2004 11:08 PM |
| Heatsinks for DoZ | ultrachrome | Solid State | 0 | 4th February 2003 09:23 PM |
| Page generated in 0.26895 seconds (35.48% PHP - 64.52% MySQL) with 11 queries |
