diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   First Pass Build. F5. General Help Needed. (http://www.diyaudio.com/forums/pass-labs/229665-first-pass-build-f5-general-help-needed.html)
madisonroberts 9th February 2013 10:29 AM
3 Attachment(s)
Hello,
I have been collecting parts for this build for 6 months or so and finally started to put it all together. I am using a 400V, dual 18V Antek AS-4218. I had been planning on going full dual mono but i cannot seem to get my hands on another Antek transformer because their factory burned down or something. There are 4 68A 600V IXYS rectifier bridges. I know these are overkill, but it is all they had in stock when i ordered them. I have two power supply boards with 88,000 in capacitance on each side (total of 176,000).
I am having trouble figuring out how to go about wiring for this configuration... I attached a drawing of how i believe it can be done below. This is my first solid state build and i am just a little bit confused. Any help with wiring this pseudo dual-mono F5 would be much appreciated. I only need help with wiring from transformer secondary and forward.
This has been an extremely fun project and i have learned A TON! I can't wait to get this thing fired up.
Thanks in advance,
Madison
Zen Mod 9th February 2013 11:10 AM
give us little bigger sketch
this one is thumbnailish in size
madisonroberts 9th February 2013 11:20 AM
1 Attachment(s)
Oops. hopefully this works. I think you can enlarge it a little bit now.
Zen Mod 9th February 2013 11:43 AM
it will work - just go for it
don't forget to enjoy ........ ;)
madisonroberts 9th February 2013 11:48 AM
Ok great. I will complete all the wiring when i get off work. Hope to hear some music tonight. Thanks
AudioSan 9th February 2013 12:33 PM
just take your time with adjusting, warm up and final(ish) adjustment:)
madisonroberts 11th February 2013 10:16 AM
When grounding the power supply boards, do i need to use two thermistors at separate grounding points? Or two thermistors on (one on each side) that meet at Earth ground? I believe this is my last dilemma.. Any help would be great. Thanks
Zen Mod 11th February 2013 10:21 AM
one ground - one ntc to chassis
you have two grounds , for my understanding
madisonroberts 11th February 2013 10:35 AM
Ok, so just to be clear. Both power supply boards ground to meet on one end of a thermistor? Also, should I leave the power transformer shield floating, or connect to it ground? I have seen both been done..
Zen Mod 11th February 2013 10:40 AM
connect both shields directly to chassis in one point
connects both main audio grounds , each through own separate NTC , to one (common) point on chassis
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
