Old 19th November 2003, 09:47 PM   #1
Bernhard's Avatar
Default Some questions
* I like to use may be switching psu with 24V.
As there are no +/- 24 available I like to connect two supplies in series and connect the middle pint to ground of preamp or whatever.
There may be some disadvantages (?)
But there are maybe less problems with 50Hz ripple ?
And much better eficiency and not so heavy.
* Are distortions random signals ?
If yes, will distortion be reduced by paralleling Fets ?
Noise will.
* In the below circuit, Nelson stated that switching of Diodes D11-14 might be a problem...
Does bypassing with small caps help ?
Greetings, Bernhard
Old 24th November 2003, 08:18 AM   #2
djk is offline djk
djk's Avatar
Looks like you have the basic idea right.
Schottky diodes minimize the noise, an RC snubber may not even be needed.
http://164.195.100.11/netacgi/nph-Pa...&RS=PN/6304138
Click on 'images', you need a TIFF viewer (free).
As you can see from fig.5 you only need one diode, not four, and only one (big) transistor on the top voltage tier.
An ordinary center-tapped transformer will provide the voltage tiers required.
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 09:26 AM
PSU for QSC amp questions rkc7 Parts 5 10th November 2005 05:18 PM
Last questions about this Madmike2 Multi-Way 9 13th June 2005 11:12 PM
Questions, questions, from newb DIYer Phatman91624 Multi-Way 41 3rd August 2002 02:52 AM
Page generated in 0.09387 seconds (64.63% PHP - 35.37% MySQL) with 10 queries
