F5c V2.0 Cascode Build Documentation
Old 10th February 2013, 01:14 AM   #11
toxic ingestion is offline toxic ingestion  United States
Coils said:
...if so maybe those Jensens make a diff, as your amp is biased higher than mine. I used panasonics.
Coils,
I just reread your note on the 4 pole caps and refer you to this document we found of assistance when picking up the Jensen caps a couple years ago, for what it's worth.
http://jensencapacitors.com/public/dokumenter/4pole.pdf
Steve
Old 10th February 2013, 05:19 AM   #12
Coils,
I just looked at the current BOM and schematic posted at the store for the FVc V2.0 board that we used. Still confusing. The schematic shows the voltage dividers for the cascode transistors to be 10 ohms (R101, 102, 103, 104), which is incorrect - this would be 1.7 amps through each rail to ground (34 volts through 20 ohms). I assume they meant to have them be 10 K ohms. And the BOM shows them at 4.7K ohms, which would be fine. As I pointed out in our build document, 4.7K or 10K or something similar is fine, as long as they are all the same and of high enough resistance to limit current to something safe and manageable.
The schematic also shows a thermistor on each MOSFET, rather than just on the center two, as is found on the board.
Steve
Old 10th February 2013, 08:22 AM   #13
zoe is offline zoe  United States
yes I see what you mean.I don't think that's right. I would adjust values with the F5T article from Mr Pass as illustrated in the V3 version
be good
zoe
Old 10th February 2013, 01:20 PM   #14
Oops. Meant to post the last one to zoe - but that appears obvious. Too little sleep.
Steve
Old 10th February 2013, 07:09 PM   #15
coils is offline coils  United States
Originally Posted by toxic ingestion View Post
Thanks for the info, I have Jensen 4 poles in my diy F3, I think I will open it up and do some measuring.
Coiler
Old 14th February 2013, 05:56 AM   #16
I am going to build a F5TV1 with the F5C boards here is some pictures of my boards
be good
zoe
Old 14th February 2013, 02:52 PM   #17
Zoe,
Looking good. Nice job on the resistors on the bottom side. I see parallel 5 watt 1 Ohm resistors on the sources of the MOSFETs. What are you shooting for with regard to bias, or is that just what you had lying around? That should sure do the job.
Just a note: on the photo of the underside of the board, some of those soldering connections look like they could be cold - but a photograph can be very deceptive and you obviously can see it much better than I.
What are you using for MOSFETs?
Steve
Old 14th February 2013, 07:18 PM   #18
cviller is offline cviller  Canada
cviller's Avatar
Thanks for putting together such a fine piece of documentation!!
I have added a link to my F5 blog post.
Old 14th February 2013, 07:57 PM   #19
soundchaser001 is offline soundchaser001  Canada
soundchaser001's Avatar
Now if only the boards were back in stock...
Old 14th February 2013, 08:08 PM   #20
cviller's Avatar
I read somewhere that someone was working on F5T - I suppose that is what people are waiting for.
F5c V2.0 Cascode Build DocumentationHide this!Advertise here!
Cviller's F5c thor61 The diyAudio Store 16 2nd June 2014 06:18 PM
Cviller's F5c thor61 Pass Labs 17 22nd March 2014 02:37 PM
Fetzilla Build Documentation Woody1911a1 AKSA 234 23rd December 2013 03:37 PM
F5c question mk57 Pass Labs 1 28th August 2012 09:50 PM
Build Documentation beaner Multi-Way 1 23rd February 2010 05:59 PM
