SemiSouth boiler room - Page 13 - diyAudio
Old 9th February 2013, 07:35 PM   #121
Originally Posted by flg View Post
Sorry guy's still wading thru this post: What do you mean reverse cunduction? -Ids?
Seems to me I've seen an N JFET cunducting like a 2sk170 data sheet?
Your, replying to a dog. A smart dog but hey, how many dogs can read and understand most of this transistor theory? let alone type? Spelling well
Yes, reverse conduction is negative drain current. My dog isn't that smart.
Old 9th February 2013, 07:37 PM   #122
buzzforb's Avatar
Well buzz, where did that come from? Under what other conditions? It's blurry and there is no legend so I'm gussing what most of it is. Are those Vgs trend lines? Are they -4.8V to -6V w.1V intervals ? I've seen this before I think and even played with the load line possibilties. I think I had a problem similar to you. I have other projects to finsh so I put it away for awhile...
This should be cleaner. No its not at low Vds, unfortunately.
...Shape the sound , Man!
Old 9th February 2013, 07:42 PM   #123
buzzforb's Avatar
Originally Posted by Semisouthfan View Post
The two images are interesting. "R085" shows the sub- to near-threshold characteristics of the depletion-mode channel design. This gives reason behind the notion that a SemiSouth depletion mode JFET can play the role of a tube and thus benefit from the higher voltage rating of the device. My business partner is an accomplished blues guitar artist and is well acquainted with the musicians love of the tube amplifier. We've been talking about the possibilities. SemiSouth put out a 650 V JFET before the end...
The "depletion jfet" image is interesting too, but if it is from the same R085, don't get too excited. This is what a common-drain (source follower) amplifier imposes on the transistor terminal characteristics. If it came from an R085, the polarity is wrong as this can't happen for positive Vds and positive Id unless Vgd is being stepped. The legend seems to show Vgs is being stepped from a negative bias. Maybe there was just a mix up in connections? Otherwise, if from the same device the two images are mutually exclusive.
Attached is an image taken of the screen of a Tektronix 370B curve tracer measuring one of my R085s with correct polarity when stepping Vgs. (Vds is on the horizontal axis at 2 V per division and is negative, Id is on the vertical axis at 0.5 A per division and also negative, Vgs is stepped in 2 V increments starting from -18 V.) I added an eight Ohm load line using the cursor function of the 370B. You can see the potential for linearity, but this is to be expected from 100% source degeneracy. The negative feedback "straightens" out the non-linearity of the transistor by using the full gain of the device.
The image represents the JFET in reverse conduction, a property of the device under intense study by my research team right now (got no choice, I have to present this research at the PCIM-Europe conference in Nuremberg in May). One caution operating this way in forward conduction by stepping Vgd: You could accidentally overstress the reverse bias on the gate-source diode of the JFET and that is a good way to create a dead JFET.
I was saving this aspect of operation for a later article, but I'll add a short section in the next one to tip the hat to the "discovery" by Buzz.
Two graphs are from different sources. Main limitation of the curve tracer is current capability at reasonable Vds.
Old 9th February 2013, 08:02 PM   #124
flg is offline flg  United States
flg's Avatar
Sorry buzz, like I said, I didn't understand enough to agree but I'm not gettin into any arguments or insulting stuff without a much better reason. I totally appreciate what you did but, I wanna try to see it myself or verified by another party. Funny, we havent seen N.P. nudge us back on coarse or throw out any crumbs
It's time to try something myself... Gotta go help my brother and brave the storm at the moment...
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 9th February 2013, 08:17 PM   #125
buzzforb's Avatar
I know less than nothing. Just showed it cause I had it.
Old 10th February 2013, 01:19 AM   #126
flg's Avatar
I had 'em too. Could of been from you? They disagree with each other because they are not the same like Mike said. I did play around with the R085 graph and I think I liked what I was seeing at the time. I gotta admit, gotta sit down and grind thru what was goin on today.
Old 10th February 2013, 01:37 AM   #127
buzzforb's Avatar
The one was mine. The other is from the same thread by somebody else. My graphs still look attractive to me, but unfortunately, i dont think thats the whole story. Seems cascode modulation could yield some nice results, but it doesntvreally need that element for any other reason than distortion manipulation. If only ther was another way to play same game. Oh well, glad we have brought in some big guns.
Old 10th February 2013, 04:12 AM   #128
I'm just beginning to understand what's under the hood of these things as it goes with audio. I'm from the knuckle dragging species. We try to power through the subtle features revealed by you all as fast as possible. Kinda fun learning about it. Like waking up and discovering there is something more to audio listening pleasure than an MP3 player and ear buds.
Thanks for sharing your stuff on this thread.
Old 10th February 2013, 04:46 AM   #129
I'ld like to quickly comment on this:
Most musicians weather it be harp, solid/hollow body elctric Guitar, or several others, are not interested in linear distortionless amplification!
The acoustic guitar produces harmonics from the almost triangle wave of the strings due to the body shape, the wood, and construction etc. The electric only guitars/instruments depend on the harmonics created by their amp. For instance, some amps have a knob on them called overdrive. What do you think that is? As I said before about tube amplification, The soft clipping is a much "Nicer sound". Tube guitar preamps purposly over drive (to clipping) the signal and at various places in the circuit there are filters and other raz-ma-taz that gives them their signature sound. It is'nt a what goes in comes out transfer curve. I eluded to odd order distortion previously. If you have an amp with a gain(overdrive?) you can crank up to 1000, but it would be clipping at a gain of 10, your guitar will sound like Jimi Hendrix! No Sh$%^t! A square wave is essentially a fundamental sine wave, with a 3rd harmonic of 1/3 the level of the fundamental, and a 5th harmonic of 1/3rd the 3rd, and a 7th(John Curl's favorite) of 1/3rd the 5th, etc., etc, etc, A pure square wave is 33.333% THD! Pretty close to what Jimi used
It's not that their on another planet, but, it's a different goal altogether and Semiocunductors have not been able to satisfy half the guitarists out there for years!
Actually, here are a couple of details which might interest you.
1) What starts off as a triangle (or any other wave) on a guitar string does not remain the same shape! The harmonics of a stringed instrument are always a bit sharp, with higher harmonics being sharper than the lower ones. That's why pianos are tuned "stretch", with low notes lower than would be assumed from an A-440 reference, and conversely upper notes tuned a bit sharp -- it's to keep the harmonics of lower notes aligned with the fundamentals of higher ones. Hence that perfect waveshape falls into a chaotic looking mess in about a second.
2) The spectrum of a square wave is third harmonic 1/3 the fundamental level, fifth harmonic 1/5 the fundamental level, and so on for every odd harmonic. Hence the harmonic contribution is 1/3 + 1/5 + 1/7, etc etc, which amplitudes sum to 100% of the fundamental over the infinite series, so a square wave can be considered to have 100% THD.
BTW, I'm willing to bet a low-feedback solid state amplifier (hi Nelson!) might sound just as good for guitar as a decent tube amp. Tube amps tend to have much lower feedback than most SS amplifiers, and the "hardness" of SS clipping is partially due to lots of feedback linearizing the transfer function until there ain't no more transfer to function.
Old 10th February 2013, 05:21 AM   #130
Loudthud's Avatar
A tube guitar amp doesn't make a perfect 50/50 square wave. Grid current tends to shift the baseline of the incoming signal. A perfect square wave sounds hollow. Many of the most liked guitar amps will make a 40/60 wave at the output with power supply ripple modulation.
The Amp Camp Amp sound good, especially with the feedback disconnected. A low damping factor and moderate impedance to the rail when clipping helps. Most solid state guitar amps now days use current and voltage feedback to raise the output impedance.
Semisouth goes Dodo ; what now ? Zen Mod Pass Labs 259 23rd January 2017 09:22 AM
Semisouth Aleph J? buzzforb Pass Labs 59 28th February 2014 06:53 AM
Fostex "boiler plate" speakers aeronautical Multi-Way 49 22nd June 2012 08:22 PM
Black Hole in your listening room; room treatment dfidler Everything Else 5 29th March 2011 12:02 AM
basic room accoustics..help design my ht room :) JinMTVT Multi-Way 4 4th September 2007 11:35 AM
Copyright 1999-2017 diyAudio
