SemiSouth boiler room
Old 4th May 2014, 11:41 AM   #351
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
You can get huge cascode devices, or you can parallel some devices with
ballast resistors for current sharing.
Old 4th May 2014, 11:56 AM   #352
woody is offline woody
Nelson in this type of application would you expect a power Jfet used as a folower to
have significantly lower distortion and used as a follower the input capacitance won't be
a problem to drive ( as you mentioned in your mosfet citation 12 article )
Old 5th May 2014, 01:22 AM   #353
aoc is offline aoc  Malaysia
It should also help improve the open loop bandwidth if memory serves me right
Alex
Sent from my C6903 using Tapatalk 2
Old 5th May 2014, 01:51 AM   #354
The one and only
I don't expect that there would be any issues. As followers, almost everything
we play with is easily driven from a capacitance standpoint. The rationale
for cascoding the follower is to take dissipation off the part so that you
can bias it at high levels.
Old 5th May 2014, 01:03 PM   #355
poynt99 is offline poynt99  Canada
Nelson,
I believe you've also noted elsewhere that followers exhibit less distortion if ran under cascode. Is that because of the increased bias current, or lower voltage across the device?
Old 5th May 2014, 01:16 PM   #356
Nelson has a whole paper about this.
https://passlabs.com/articles/cascode-amp-design
Old 10th August 2014, 03:18 AM   #357
Semisouthfan is offline Semisouthfan  United States
Default What's the Buzz - Part II
Attached is the second part in a three part series entitled "What's the Buzz?" The document and a supporting spreadsheet are included in the zip archive. I had to reduce the resolution of the pdf document to fit under the upload file size limit imposed by the forum. If you prefer slightly better resolution, email me and maybe I can arrange for the higher rez document to be available on a file uploader site.
Many of you have encouraged me throughout the more than one year it has taken me to research and write the second installment. Well! I"m glad to finally be able to push the post button and get this off my chest. It's like a good confession, it really puts the mind at ease.
Anyway, as before, this is the next step in my goal to understand why you guys like the SemiSouth JFET so much.
As before, I hope you find it both worthwhile and entertaining to read. The subject of Part III, negative feedback, is hardly a topic calculated to get the next one out in a timely manner, but your encouragement does really help.
Old 10th August 2014, 04:05 AM   #358
Apogee is offline Apogee  United States
Apogee's Avatar
Thumbs up Awesome!
SemiSouthfan,
I/we really appreciate you taking the time to put this together. I'm looking forward to learning from it. Part I was excellent.
I keep hoping the products will get re-released at some point. I think the demand would be there.
Thanks again,
Steve
"If I had my life to live over again, I would have made a rule to read some poetry and listen to some music at least once a week." - Charles Darwin
Old 10th August 2014, 04:20 AM   #359
labjr is offline labjr  United States
Good reading! Thanks
Old 10th August 2014, 08:57 AM   #360
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
amusing and witty
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
SemiSouth boiler roomHide this!Advertise here!
Semisouth goes Dodo ; what now ? Zen Mod Pass Labs 265 25th May 2017 08:07 PM
Semisouth Aleph J? buzzforb Pass Labs 59 28th February 2014 06:53 AM
Fostex "boiler plate" speakers aeronautical Multi-Way 49 22nd June 2012 08:22 PM
Black Hole in your listening room; room treatment dfidler Everything Else 5 29th March 2011 12:02 AM
basic room accoustics..help design my ht room :) JinMTVT Multi-Way 4 4th September 2007 11:35 AM
Copyright ©1999-2017 diyAudio
