#11 |
The setup I show allows you to test at 70% of Idss by changing Rd. The Quan-Tech 5173 semiconductor analyzer uses something a bit more sophisticated, but you get the point.
#12 |
expert in tautology
where was the 17.6 found?
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#13 |
I bought a few JFETs from C-J to replace some that were damaged in my preamp from ESD. Since C-J supplied supposedly graded parts (for which they have to charge much more than for nominal parts), and since I am anticipating future damage to those parts again (it's very dry in the house and ESD events are frequent) I bought a large batch of nominal (ungraded) parts off the Web and want to make sure I can select the ones that are consistent with those C-J sent me. To do this, I thought it best to characterize both Vp and Idss, i.e., do it for the graded C-J parts and then select from the nominal parts those that have similar Vp and Idss values to the graded parts.
I have used Loudthud's method but with a 1M ohm resistor from source to ground (for the N-channel devices) -Kofi |
#14 |
#15 |
expert in tautology
partialresponse, what type of jfets did you buy and from where? MANY of the jfets being sold on the web now are bogus re-badged parts that do not meet specs because they are not the parts that they say they are.
#16 | |
-Kofi |
| Jfet matching setup | lloop9 | Equipment & Tools | 15 | 23rd November 2011 08:48 AM |
| Matching jfet at what voltage? | Sunsun22 | Solid State | 3 | 29th July 2010 11:57 AM |
| JFET sorting by Ron? | scott wurcer | Solid State | 19 | 19th May 2009 02:50 AM |
| Ono JFET matching | AuroraB | Pass Labs | 12 | 26th July 2007 12:20 PM |
| JFET matching | Nelson Pass | Pass Labs | 19 | 19th February 2006 03:31 AM |
