#71 | |
j310 Transistors | Mouser But who knows for how long, the Fairchild version is already "end of life"...
Regards, Georg |
#72 |
hi everyone. I will revive this thread.
I do think now that my b1 has a problem, probably because of my fault musical coherence is simply not there, and after changing my speakers and source, and now my preamp, I know that the b1 is seriously having a problem. Left side plays louder then right side, slightly, but its confirmed. I have switch to no preamp at all, and well music is back. I have no musical coherence with the b1, its as if some things are slow and some thing are fast, or whatever, hard to explain really, but it almost makes me dizzy listening to the thing. All I hear is a bunch of sound and no music coherence. I just want to take back my comments about the B1 and also ask for help, I now think that its how I build it that is the problem. I will measure the LSK389 to see if they match, or maybe they are fake? I met the guy in montreal in a parking lot for the LSK389. but I reached him via the distributor site and he gave me all the documentation and everything, seems legit, but I will measure... Then, if they measure right, I will just order a board from Mr. Pass because I hardwired the pre amp, maybe I made a mistake, but ouf, its been a year I use the pre amp and I just realize that all this time, that was the problem, nothing else. I feel stupid. One question about the boards. If I buy the board, can I still have two outputs and add a simple crossover for one of the outputs? this is how I did my pre: e will have two times C101 and C201, which we shall call C101a/201a for the "Full Range" or better "Full Bass Range" output and C101b/201b for the "High Frequencies" or better "Limited Bass Range" . C101a/201a will be 2.2uF, C101b/201b will be 33nF. R104/204 and R105/205 will also have an 'a' and 'b' incarnation. For 'a' we will have R104a/204a being 1K or lower (uncritical) and R105a/205a being 1M. For 'b' we will have R104b/204b being 1K or lower (uncritical) and R105b/205b being 1M plus switchable resistors of 100K & 33K to adjust the at which frequency the low frequencies are cut out for this output. I guess I cannot implement many outputs if I buy the boards?
Actual top 5: 1- Kettel 2- Miles Davis 3- Gil Scott Heron 4- John Coltrane 5- Dinosaur Jr. System: EC designs SD1 SD Player-> Pass B1-> PP 6B4G-> 3 way. Last edited by murphythecat8; 18th April 2013 at 01:23 AM. |
#73 |
Compare the outputs as you currently have them.
Swap the outputs and compare again. swap the inputs and compare again. Which component has the fault? |
#74 | |
Howver, my crossover is problematic. when the crossover is on, I have a a different signal. the input and output does not picture the same on a oscilloscope.
Actual top 5: 1- Kettel 2- Miles Davis 3- Gil Scott Heron 4- John Coltrane 5- Dinosaur Jr. System: EC designs SD1 SD Player-> Pass B1-> PP 6B4G-> 3 way. Last edited by murphythecat8; 19th April 2013 at 09:35 PM. |
#75 |
high pass filter close measured at J3
then, I adjusted the out signal at 1volt rms @ 1Khz. 4- Switch S2 open (hipass open), same output, 1 volt rms @ 1Khz. 5- I have adjusted the signal generator to 0.707volts rms (-3db) @ 106Hz (cut off frequency High Pass Filter circuit were RT= 47Kohms Channel #1 >>>Input, Channel #2 >>>Output Without High Pass Filter (S2 close) >>>Output at J3 >>>1volt rms @ 106Hz With High Pass Filter (S2 open)>>>Output at J3 >>>0.707volt rms @ 106Hz (-3db). However, its clear with the pictures that something is wrong The two picture has the same signal shown. the upper signal is the same and the input#1 , and the output #2 is the down signal...
Actual top 5: 1- Kettel 2- Miles Davis 3- Gil Scott Heron 4- John Coltrane 5- Dinosaur Jr. System: EC designs SD1 SD Player-> Pass B1-> PP 6B4G-> 3 way. |
| Mesmerize B1 vs Original Pass B1 - please guide me! | KT | Pass Labs | 9 | 6th September 2012 05:57 PM |
| Pass B1 Buffer | mantha3 | Pass Labs | 2 | 26th January 2012 11:35 PM |
| Pass B1 DIY - Need Help | jung4g | Pass Labs | 28 | 25th January 2012 03:00 PM |
| Need help with Pass B1 Buffer | benproiii | Analog Line Level | 0 | 30th August 2011 04:18 PM |
| Wanted: Pass B1 | macnugget | Swap Meet | 2 | 21st April 2011 02:11 PM |
