I m too not sure about my pass b1 - Page 7 - diyAudio
Old 1st February 2013, 02:21 AM   #61
Jay is offline Jay  Indonesia
Default Relax... Just check the power supply
Murphy was comparing B1 with WIRE. So naturally the WIRE would win, especially through headphone audition where power supply NOISE will usually be heard.
AFAIK, the original B1 power supply is only on-board regulator. It was advised to have external regulator. And it was not a perfect regulator.
Check also if there is wrong resistor value that will affect impedance.
K389 is imo better than K170.
Old 1st February 2013, 04:13 AM   #62
okay thanks Jay, that what I thought really. Its normal that I hear a slight degradation and I never said that the b1 sounded bad for god sake. still I will measure the jfet. Also, I do not use a board, its point to point wiring.
For the powersupply, I have a regulated powersupply WDU12-1900 - TRIAD MAGNETICS - AC-DC CONV, EXTERNAL PLUG IN, | Newark/element14 Canada
then:
PSU Jack -> 3.3 Ohm -> 1,000uF Silmic -> choke -> 1,000uF Silmic ->
Supply to B1 circuit.
What can I do to upgrade that?
Old 1st February 2013, 05:45 AM   #63
buzzforb's Avatar
2sk170bl. Pm me your address.
...Shape the sound , Man!
Old 1st February 2013, 06:14 AM   #64
lupulin is offline lupulin  United States
Default psu question
perhaps it will sound better with 18 volts rather than 12?
Old 1st February 2013, 07:23 AM   #65
danny_66's Avatar
Definitely change the pot to something that is resistor based.
Here are some examples:
δ1 relay-based R-2R stereo attenuator
Dantimax RelVol
HifiCollective
ebay
Old 1st February 2013, 09:50 AM   #66
The LSK389 is the equivalent of the 2sk389.
This is a dual jFET in a 7pin package.
The two jFETs are roughly equal Idss and when wired properly would make an excellent thermally coupled B1.
Do not dismantle. Measure Vgs for the 4 jFETs.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 1st February 2013, 10:04 AM   #67
buzzforb's Avatar
Should be equal if not not superior, assuming a great many things.
Old 3rd February 2013, 12:34 PM   #68
gk7 is offline gk7
Originally Posted by brianco View Post
... LSK389 has incorrect transconductance. [The B version is but marginal],
No, its perfectly suited. (2 matched 2sk170 equivalents in one package.)
LSK370 is the recommended alternative choice.
No. LSK370 is a multicolor LED made by Siemens.
There is no FET named LSK370.
Old 3rd February 2013, 12:40 PM   #69
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I was looking for a j310
could only find it as SMD
I guess all new jfets are SMD
probably not designed to drive ClassA power amps
Old 3rd February 2013, 12:50 PM   #70
buzzforb's Avatar
Bf862 is alternative smd. Can solder leads to pin and pkug right in.
Mesmerize B1 vs Original Pass B1 - please guide me! KT Pass Labs 9 6th September 2012 05:57 PM
Pass B1 Buffer mantha3 Pass Labs 2 26th January 2012 11:35 PM
Pass B1 DIY - Need Help jung4g Pass Labs 28 25th January 2012 03:00 PM
Need help with Pass B1 Buffer benproiii Analog Line Level 0 30th August 2011 04:18 PM
Wanted: Pass B1 macnugget Swap Meet 2 21st April 2011 02:11 PM
Copyright 1999-2017 diyAudio
